You must have got a bad cdi from the start, poor quality control. I have rode 60 miles in one day, and about 700 miles on the same stock cdi.
If the carburetor is on too much of a angle, it will let you know. You only need to level it out if...1) leaking fuel from the tickler or throat. 2) If the engine starves for fuel (float too low and not filling up fast enough).So I might have to order one of those Z things. I Hope not. Thanks
The spark plug is fine. I got plenty of room there. It just the two wires, that are coming from the carburetor at the top. That are hiting the top of the bike.There are some "shorty" sparkplugs too, like the ones that are used in chainsaws and weedwhackers; try some of these in your build just might give you the clearance that you need. BMF
Yes it is the CNS crab, and it came with the jet Kit for a extra $10.00. Well I hope it worksDid you say 2 wires out of your carburator? And you got the "Jet" kit? That kit comes with an NT carburator so I'm wondering if you didn't get the kit you ordered. I suppose it could be well and fine but if you do have the carb with 2 wires then I think you have a CNS carb.
It doesn't have the best reputation. So if you have troubles getting the engine to run and you have checked for spark, it may be the first thing to replace.
Thanks, I will try that.I don't know if it's a good comparesion but I have two 48cc bikes one with a cns2 and the other a nt, the bike with the cns2 is faster by far. It take a little to dial it in but it works after you tune it in. Below is the thread that Biknut did on a 66cc with the cns2.
http://www.google.com/url?q=http://...ds-cse&usg=AFQjCNEMeK-D7f3yMBWUu2n7S9FzA2eR7g
