I need to find some TANKA oil. I have been using Pennzoil two stroke oil 32:1 and I get black oil splatter all around the muffler joint if it is not covered with a hose. I have a question on the Solex clutch. When mine disengages with the motor running. The motor gets very rough and noisy with what sounds like a lot of grinding. Is this normal for the Solex clutch?
I have attached pictures of the Solex mounted to a mountain bike with front suspension. I built two new motor mounting plates with the rear end attached to the brake mounting screws and the front end supported with a tube attached to the fork fender holes. I moved the springs to the outside to give more clearance for the tires.
Interesting.
I have thottled back many times and the speed will go down to walk speed but the clutch never disengages. I'll have to try that while braking to see if I can stop the bike and idle through the clutch.
I am in the process of re-routing the throttle and compression release cables below. I may have to do the head shave thing as I don't think I'm going 15 on this. But to tell the truth, 15 is fast enough and it starts so easy...
If you are interested in a front wheel drive friction kit - check out our Improved Bike Bug - Google Bike Bug and it will take to our site.
USA Made 30 warranty - tested it before market - teenager ahd 5,800 miles in one year - no repairs. Plus engine can be removed from bike for safty or storage with no tools.
CBS did a news clip also that is on the site. Have both front wheel and rear drive models.
t There are things that can be done to make them run better. I bought 2 and they both ran poorly. I discovered that the heads needed to be shaved .100" to bring the compression up to tha Solex specs. The run fine now.
