I'm having electrical problems and I don't have any testing equipment. a buddy of mine has a fluke meter. can anyone tell me if we can test the cdi and the coil with a fluke meter and also how to do it and what readings we should look for?
I know, I know...you don't like digital meters.I have no use for digital meters. Especially when trying to read voltage. I rely on my venerable Simpson 260 analog VOM that is rock steady and reliable.
Here's some ohm readings that have proven to be reasonably accurate for testing the electrical components. Readings can vary but if you're in the ball park you should be good to go.
And Barley Awake is right, Fluke is an overpriced product with a word-of-mouth reputation. Simpson is the better choice.
Use Low Ohm-Meter Scale About 200 Ohms
Magneto Coil
1) Check Ohms between BLACK wire and WHITE wire. Reading should be around 2 Ohms: Mine is good
2) Check ohms between BLUE wire and WHITE wire. Should be around 300-400 ohms.: Mine is good.
CDI
Use Ohm Meter High Scale About 200-K
1) Positive lead on BLUE wire and Negative lead on BLACK wire should read infinite (no activity): I have 3.69
2) Positive lead on BLACK wire and Negative lead on BLUE wire. Should be about 130-150 K-ohms: I have .367
3) Positive lead on Spark Plug wire and negative lead on BLUE wire. Should read between 135-155 K-ohms: I have 2.91
Switch to Low Scale 20K
4) Measure between Spark Plug wire and Black lead. Should be about 2.5 - 2.7 K- ohms: I didn't check
And it still doesn't produce a spark?I have a new CDI installed.
Terry
The volt meter shows the plug has electric but I can't read the amount because of the speed of the charge. I'll try again to see if I can see a spark.And it still doesn't produce a spark?
I like it.....
