I have no use for digital meters. Especially when trying to read voltage. I rely on my venerable Simpson 260 analog VOM that is rock steady and reliable.
Here's some ohm readings that have proven to be reasonably accurate for testing the electrical components. Readings can vary but if you're in the ball park you should be good to go.
And Barley Awake is right, Fluke is an overpriced product with a word-of-mouth reputation. Simpson is the better choice.
Use Low Ohm-Meter Scale About 200 Ohms
Magneto Coil
1) Check Ohms between BLACK wire and WHITE wire. Reading should be around 2 Ohms
2) Check ohms between BLUE wire and WHITE wire. Should be around 300-400 ohms.
CDI
Use Ohm Meter High Scale About 200-K
1) Positive lead on BLUE wire and Negative lead on BLACK wire should read infinite (no activity)
2) Positive lead on BLACK wire and Negative lead on BLUE wire. Should be about 130-150 K-ohms
3) Positive lead on Spark Plug wire and negative lead on BLUE wire. Should read between 135-155 K-ohms
Switch to Low Scale 20K
4) Measure between Spark Plug wire and Black lead. Should be about 2.5 - 2.7 K- ohms
Glad to hear that Tom is "Old School" and has practical experience! The Simpson 260 meter is a required meter for
business band radio alignment. Digital meters are about worthless unless you are checking a power supply for
critical supply voltages on a digital device but is absolutely worthless for tracking a voltage for alignment and
adjustment. A VTVM meter is used for high impedance insertion using a RF probe since the meter does not load
the device. I've built and worked on CDI systems since the middle 60s and a Techtonics storage scope is the only
device for analyzing the CDI systems since the rise time on a capacitor discharged through a SCR high and
voltages are lethal from 400+ volts up and fast. You will know the mistake if you get across the coil! The SCR
switches the high voltage across a ignition coil and the spark is hot on the plugs and will fire through oil. CDI
ignition systems are the only way to go. Good knowledge Tom!
![Thumbs Up (^) (^)](https://motorbicycling.com/images/smilies/thumbsupsmileyanim.gif)
