Ok, didn't book too much work this week, sort of a vacation. Anyhow the extra free time gave me plenty of opportunity to get some real progress done on the Merkel. The primary drive quill and sprockets were first on the list, they can be seen in the photos with the large and small sprockets attached, you can also see the oilite bushings in each end that the crank spindle rides on.
Next came the crank spindle it's self and the drive sprocket used to pedal the machine (above). It all seemed to fit together nicely and the cranks were bent slightly outward in order to provide clearance between them and the clutch on the left and the flywheel on the right.
With all that loosely in place it was time to tackle the rear sprocket. I was going to weld a flange to the hub as I did with the BSA build, but after examining a 'donor' wheel and sprocket combo it was decided to use that instead as there was very little needed to do other than close in the rear forks slightly to accept the narrower hub...and there was a nice coaster brake, which will keep the handlebars clean of extra levers and improve the overall look of the finished machine.
This last shot is an overhead view showing the layout of the chains.
