G'day all
I've got a question for the oil tech-heads, and i know it may be a very stupid question.
Today, i was pouring out some 2-stroke oil and also some ATF into smaller containers.
They both seemed to have a zero weight viscosity and felt very similar rubbing between forefinger and thumb.
I've heard some people use ATF as a diesel fuel lubricant and others have run diesel engines on straight ATF with the engine not suffereing any ill effects.
Ok, can some knowledgeable person enlighten me as to the technical differences between ATF and 2-stroke oil and if you could substitute one for the other without reducing engine life or could you mix ATF and 2-stroke oil if that's your only option.
Fabian
Fabian
