http://motorbicycling.com/f36/briggs-kick-start-motorbike-25549-6.html
see post #58 BriggsBiker pictures that show a forward tilt and I suspect no problem with oil, I’ve wondered, but you may check with BriggsBiker
http://motorbicycling.com/f36/briggs-kick-start-motorbike-25549-5.html
see post #41 my comment on tilt of engine from the same thread as above
Pictures I have attached of the guts of the engine and the splash fork. For level operation, I noticed it rotates a sweep of the fork from the side by the breather (aft) down into the oil. Then the fork moves across and upward to the front up and out of the oil at an angle by the time it is halfway forward.
A back tilt leaves the fork in the oil for a longer period of the sweep when tilted back I presume from this. It would have to be tilted more than my about 22.5 degrees I guess I have tilted back to get into the oil breather. The channel way to it from the crankcase would help stop it anyway.
Tilting forward I know it would be further from the oil breather so that’s not a problem. Someone said that they thought it would maybe cause oil to get too much on the bottom of the piston. I don’t think it should really matter, just getting enough oil where it won’t leak out like the breather.
So check the pics I have and from BriggsBiker check and see how it works.
Probably not a problem
Measure Twice
PS the Briggs Engine is an 80202 0430 Model, ? 3hp
