I am in the planing stages of my next build and I have my heart set on using a Worksman frame as a starting point. ...
I have two major question
1. Are Worksman bikes as beefy as they look? What is the tubing size?
2. How much power can one of these frames take before it tears apart?
I know some of you might think that this is totally ridiculous but "we all build for different reasons" to quote Hoodoo. This is just a dream I have that I need to fulfill.
Thanks for you help guys
First of all, you're not going to fit any 2-stroke engine much more than 2-3 HP into a Worksman frame anyway, without cutting the frame up and re-welding it--at least, if you want it inside the front triangle. You might as well just buy a head tube and bottom-bracket tube and scratch-build the whole frame around whatever engine you want.
-Or did you want to do this
without any welding? Because that drastically limits your engine options, unless you pay somebody else for a custom frame.
Second of all, a typical adult puts out 1/4 to 1/3 HP on a bicycle, during normal use. A top athlete can put out maybe 3/4-HP sustained. If you want to know how much power & speed that bicycle frames are built for, that's about it.
Most people who put bigger engines on motorized bikes use rear non-bicycle hubs, since the torque from a 4-5 HP engine is way beyond what bicycle hubs are built to withstand in normal use.
Also in my opinion,,,, when you get to speeds beyond 40 MPH, you should
really have functioning full suspension--and that means
oil-dampened suspension. There's some bikes people have built that look like they'd work just fine at 75 MPH--and other ones that would be scary at half that speed.
