BiMoPed said:They are so confident about the Opti-4 oil that they offer to double your engines warranty!
Can I get that in writing with the agreement to buy my blown motor if it does?![]()
Hi sketchman and GEJoeGEJoe said:I posted just ahead of you today in the 100:1 section. Does Opti-2 have a warranty to cover the cost of repairing my engine? It will cost only parts and shipping from Dax.
Interlube is so confident in Opti-4's ability to increase performance and extend engine life thru its Eutectic anti-wear additive that when a six-pack of Opti-4 is purchased with a new piece of 4-cycle power equipment, Interlube will Double the engine warranty on internal engine parts.
Interlube takes the standard manufacturers engine warranty of two years and Doubles it to four years. Not only is your engine protected from wear, but you are protected from potential costly repairs for an additional two years.
At the time of equipment purchase, simply fill out the warranty registration contained in each six-pack, mail the top copy to Interlube. The middle copy stays with the servicing dealer where the oil and equipment were bought, and the bottom copy is retained by the purchaser.
If a failure occurs during the extended warranty period, the equipment is taken back to the servicing dealer who then files a warranty with Interlube instead of the engine manufacturer. It's really that simple.
Interlube has been in business for over 20 years and has proven to be an industry leader in anti-wear oil technology.
Based on what you know now, would you still say this if a customer started out with Opti at 100:1 since the problem seems to be "switching" to it after running more oil up to a point?I won't warranty 100:1 engines.
Please Do NOT call Paul with your questions about Opti- 2.Again.. If your Jets are so rich, no re jetting may not be needed. If you are using a high performance 2 stroke, you will have to work your way towards this leaner mix ratio and it will require work. It is intrinsic. Since a High performance 2 stroke is typically Spot on Jetting. Again.. Intrinsic. This is true with any 2 stroke mix ratio that if you start to remove the oil, you will need to fatten the jet. It is a displacement function and again..Intrinsic. If you have any problems with Opti2 and going to 100:1 mix, the problem is not the oil but is jetting. You can call Paul at Opti for more Info. The posts in here by me are not intended to anger or insult anyone. I am learning a lot from all this. If you are able to switch to 100:1 mix and not change jetting, then you are a lucky. And you need to know this.. Call Paul at Opti. Also.. Paul can give you contact info on racers using Opti 2 and they too can explain to you all that are interested on what has to be done when going opti2 100:1. Here it is again.. Paul at Opti 1-800-332-5851 . Since it is a 1-800 number there is not excuse to continue any arguments on doing this 100:1 mix endeavor. Just call the 800 number. I have no more help to offer.
The people who make STP engine treatment have been in business for a long time too and have sold lots and lots and lots of it. People swear by it. Claim it saved their engine. Claim it has worked for years in their engine and far surpasses the invention of sliced cheese in every way, etc, etc, etc,.Interlube has been in business for 35 years and sold enough oil for
400 million gallons of gas!
Yeah, that's probably why they now mix at 70:1 with the packets. Too many calls from people with fried motors.
This is totally untrue, there have been absolutely no calls about fried motorsGoing from 32:1 to 100:1 and not doing anything other on a high performance 2 strokeis a rookie mistake. But.. Do not take my word for it. I never said I would never use Opti. I said I would never go 100:1. Paul is the Opti Expert. Thanks
No offense to anyone, but opinions and personal experience(without empirical data) is just not enough to sell me on anything. I'm a staunch skeptic till something is proved thoroughly. Lots of people run their choice brand of "magic in a bottle" and have for years and seriously believe that it is the reason their engine has lasted so long and run so well. I'm perfectly ready to believe it too, if it can be proved.
Interlube is claiming some weird stuff(compared to what we are used to). I don't think the skepticism is all that unwarranted, but I'm also ready to go with it and will start my new engine out on it at 100:1, beating on it the whole time. If it lasts it'll be worth it just for the oil savings.If not, I'll tear it down and see what's happened.
