I found a motorcycle speed calculator on line that allows the input of various ratios, tire sizes, and rpms. At 3600 rpm's the bike is capable of 74 mph, at 6500 rpm's it is capable of 132mph. Salt Flats anyone? :O So this set up, if you had motorcycle tires and a long strait, and you were tucked in laying on the tank, you could go as fast as a real board tracker of the day, no problem. If vintage motorcycle tires are available through various outlets they would need to be put on a motorcycle rim because they can't fit bicycle rims.
