The low (top speed ratio) on the top of my head is .90:1.Sounds great. I can't wait. I'm curious. Do you know the low and high ratios that trans creates?
Nope, it is in black and white from the manuel. The Comet is unique because it can reach overdrive ratios. It is in fact .90:1 on the absolute low end of the spectrum. You may never see it unless you are going for a speed record, but it is there.That seems impossible, or at least implausible.
The 90:1 I mean.
0.9:1 maybe?
Got it here:where did you get the parts for ur torque converter
No, I got the one with the 40/41 chain, which is usable with the china girl rear sprockets btw. You need to run 41 chain however to do this. It is really cheap and you can get it at larger lawn equipment dealerships.so u use a #35 chain ?
Didn't see the decimal the first time. We typed the same thing.Nope, it is in black and white from the manuel. The Comet is unique because it can reach overdrive ratios. It is in fact .90:1 on the absolute low end of the spectrum. You may never see it unless you are going for a speed record, but it is there.
Gotcha. Decimal point.Didn't see the decimal the first time. We typed the same thing.
0.9:1 = .90:1
A zero in front makes it easier for us blind peoples.![]()
I don't think so, you need real #41 chain to make it work. Like I said, it is the number one or two most popular roller chain for professional lawn care equipment, so you can get it anywhere, which is nice.can i use the stock chain,hd 410 bmx chain ........or should i just buy a chain from the site?
To be honest I don't think any stock bike will fit without major work. I can give you dimensions if you need them. With the Comet you need to have a particular height (assuming you want the piston almost strait upward) to have the chain in line for the rear sprocket.Ok time to get with it. What style bike do you think this motor will fit? How did you get your peddles to make it around that fat motor? (links please) I need to get started and any help would be realy great. Thanks
