Hi, all. I am so glad I found this forum. Spent about five hours reading here last night after completing my build and making myself look like a fool in front of the neighbors when it wouldn't start.
It's a 2 cycle Chinese kit from bikemotorkits.com. The sticker on the magneto cover identifies the mfr. as Rico group. The problem is the apparently all-too-common "no spark" one. Fuel is reaching the plug. Clutch seems to be working as it should. But electrically, it's dead. So I printed out some of the recommended CDI and magneto test procedures and headed out to the garage this morning. I'm including my results here in the hope that someone can help me interpret them. My read is that both the CDI and magneto are defective. But since the odds of that should be relatively low, maybe someone can point out a mistake I've made or offer a suggestion.
Here are the tests I ran. My results are in parentheses following the expected values posted in the forums:
CDI:
Black to Blue 1150 Kohm to 7.6 Mohm (No reading)
Black to plug 2.6 Kohm to 2.17 Kohm (2.4 Kohm)
Blue to plug 1150 Kohm to OPEN (No reading)
Magneto (all solder points under the cover seem good):
Blue to White 327 - 349 ohm (No reading)
Black to Blue 327 - 347 ohm (No reading)
Black to White 2.1 ohm (3.1 ohm)
Black to GND 0 - 0.3 ohm (1.4 ohm)
Blue to GND 327 - 347 ohm (No reading)
White to GND 2.1 - 2.3 ohm (3.4 ohm)
Thanks in advance for any help. I've also sent the results to the vendor, but I'm thinking I might get a quicker response here...
CDI:
