Eric,
Toss the manual, wire your engine like the diagram above, solder the connections and use heat shrink tubing to protect them.
Close the choke, depress the primer button for a few seconds, 3 to 5, hold the clutch lever in and start pedaling. Get up to about 8 to 10mph, let out the clutch, continue to pedal while twisting the throttle just a little.
That puppy should fire. When it does, keep going and don't try to stop and let it idle. You'll need to reach down and open the choke (lever down)These little engines run best when they're warm. They can be problematic when cold.
Good luck, let us know how things go.
Thanks for the pictures. Now the next ones I want to see your dad smiling, like this
