Yepp, it's confirmed NT, because it says on the plastic filter cover and has just a idle screw. Good tip on riding to break in, I thought letting it rev in place was better...Glad I know now, thanks.If you have only one adjustment screw then you're lucky and have the NT carburetor. The other one is notorious for causing problems.
I'm a little concerned about you wanting to get the engine running then sit and let it break in with the clutch disengaged. That's not the way to break in a new engine. It needs to be run and needs some load on it. Sitting for too long can cause an overheat condition due to the lack of air flowing over the cooling fins on the cylinder and cylinder head. Get it started then ride it. Don't baby it or it will take forever to seat the rings.
Good luck
Yeah, that does look good.
Check the spark, that thing looks straight, it should run.
Have the kill switch connected. Capped white wire? How do I get to the MAG?Quick question: have you disconnected the kill switch yet? Made sure the white wire is capped? I recall a couple people having to replace the magneto, too, because it was just not right. If the teeny wires on the mag are sloppy, you may not be getting enough spark.
And ... What's your plug gap again? I have to think that if it sputters but doesn't stay running that it's a spark thing.
The kill switch, the button by the throttle. Disconnect it completely. Black to black, blue to blue, white to nothing and make sure it's just taped over so it doesn't short anywhere.
Check your plug gap for sure, it's important. .030" is a good place to start, mine likes .026. If the gap is too wide, you may not be getting spark under compression even if the spark test with the plug out is good.
The magneto is under the left front engine cover, where the wires go. Don't worry about that quite yet.
The bullet connectors can be dodgy. Mine work well after I crimp them a bit and heatshrink. Lots of people strip and solder instead. You can strip and twist the wires together at least temporarily to eliminate the connectors as a problem.
I notice that in the 4th pick I can see that a GREEN wire is grounded to the frame under that screw you have screwed into that spacer for the front mount.
what is that wire hooked up too?
does it hook to the kill switch?
or does it come from the coil?
the reason I ask is that some kits have a green wire and a blue wire coming from the coil and if yours is that way then that geen wire is grounding the coil to the frame and causing your NOT firing issue.
But it isnt clear in the pic just where that wire is coming from so I could be completely wrong in thinking it is coming from the coil.
One wire from the kill switch should be connected to the blue wire from the coil and the other should be grounded to the frame..
best wishes I hope you're up and running real soon.
Peace
I see the picture that the white wire goes no place? this is what I want? just cap it? Then the kill switch wires go into the CDI box wires?
It's a Cranbrook and we couldn't get the pedal chain tight, because taking just one link out and it lacks just a hair in matching up to the link. We wanted to get this thing running so we just threw the tensioner on the pedal chain since it's just for startup. I'll try a half link later on, but for now I just want to get it running. After that, we are putting back the fender, chain guards and painting the tank the same color as well as the front motor mount.I like that you were able to get the motor-side chain installed without using the tensioner.
Maybe a half-link on the pedal side will get rid of the tensioner for good?
I like to equip my builds with a derailluer, so I don't have to worry about pedal side tension at all.
I like the cruiser style frame you have, Schwinn Landmark comes to mind of a cruiser type frame with derailluer
Clip the kill switch wires off for the time being. If the kill switch is bad (and it might be), it may be drawing power from the mag, which is not allowing the CDI to generate a spark. And when/if you decide to wire them back together, splice one into the black and one into the blue. The kill switch will actually work that way.
