My engine still bogs under power...
When i pull the clutch in to idle its runs WIDE open ...
Made sure the throttle and choke slides are aligned and working properly...
And on a side note a ton of gas splashes out from under my gas cap whats up with that.
Let's start there.
Pull off the air cleaner and look inside the carb.
There should only be a sliver between the bottom of the sliding barrel and the bottom of the carb with no throttle. If it's a bigger gap it could be your throttle cable, the idle set screw, or the barrel is simply in turned 180 wrong.
When you can look in and work the throttle and the barrel goes up and down nice you are set.
Next check your choke cable and slide.
It's little brass barrel needs to go all the way for no choke. If it is getting hung up it is dumping in fuel in.
Once you can get it to idle set the idle gas/air mix.
Twist it's adjuster in until it starts to die, then out a 1/4 turn or so.
The plastic ring insert is 1 piece with a single grove.
You can still use it, just seal the opening around the carb at the intake pipe.
Or, get a Pirate Cycles CNS intake for $20.
It's in the Manic Mechanic section.
You don't need the plastic ring or any sealant or anything so I'm told.
I'll let you know, I have 2 on the way.
These carbs can and do work well when you get it on good enough, it's just a royal pain.
I do love the choke on the handlebars and the separate idle circuit has it's advantages.
ABOUT THE CNS JET
My problem now is I need to get more fuel in the mix.
I'm running as rich as she'll go, needle all the way up (clip on lowest setting).
I have a very light tan on the plug so it's not to lean to burn up, but when I get wound out under load I can tell she's starving for fuel, and I don't even have the larger perfectly ported intake on it yet.
So next is a larger Jet.
These carbs seem to be a Makuni knock off.
The CNS jet looks like this.
It has no markings on it all, so no size indication.
This should be replacements for them.
Note they are marked and range from 50 to 180 in 5's in size.
Any clue whatsoever what the CNS carbs we get is numbered?
