Hi silverbear. I think it is a Puch front fork. I'm working with oppanoia on his build and his is definitely a Puch. Most bicycle fork necks are 1"-24tpi, or 1 inch diameter with 24 threads per inch. Over the years I've collected a large amount of used bicycle steering head cups, bearings and cones and can usually come up with a combination that fits with no modifications other than maybe a spacer washer. We rethreaded the forks on oppanoia's because they were so close to standard, it was just a simple matter to run my die over them. Years ago I purchased a 1''-24 adjustable die just for chasing and rethreading bicycle fork necks. I've used it many times because you know how some forks get beat up and the cones won't thread on easily. Or the neck is too long and I can cut it down and add threads. I have always used 26'' wheels with moped forks as most have plenty of room. I usually need to take the legs apart and put a 1'' spacer above the spring so they won't hit the tire when collapsed. They come apart very easily for painting and offer a great ride with an inch or so of travel. The only problem is front fender mounting may be a challenge. The lower legs on most moped forks have frender brace mounting bosses or brackets either threaded or drilled through. Obviously a fender mounted on the lower legs will move with the wheel, while mounting to the bottom of the lower triple tree would not. I haven't used a front fender on any of my bikes using moped forks because of the overall look I was after. You may need a bit of extra clearance obtained by a longer spacer added to the inside. The forks have plenty of engagement allowing spacers without weakening. I highly recommend getting the front drum brake that goes with the forks you use. They lace right into a 26'' bicycle wheel using cross four pattern and standard length (around 10 5/8'' long) spokes. A friend of mine used the cups, bearings and cones that came off the moped with his forks on a 50's Schwinn. He's a machinist and he just made spacer bushings to enlarge the cups to fit. I like the little headlamp brackets on most forks. You can get the light that goes with them or go with an aftermarket unit. I like the headlights with the built in speedo and ignition switch. Lots of choices out there. Moped controls are very good for motorized bike projects. They offer brake, throttle, choke and stoplight all on the right side and are usually straight pull cables that follow the handlebars. The left side has brake and compression release levers and another stoplight switch. Very clean and you can use grips of your choice. Hopes this info helps. What really helps is having a moped shop within driving distance. I can just go to Myron's Mopeds of Fullerton and measure what I need. I have purchased several forks on ebay also. Let us know what you decide to go with.
