Bikeguy Joe
I think it's a lady's thread by the username.
So it looks like i will need to buy some kind of file to file this key. Does anyone have any suggestions of what type of file i should get? Also if anyone has a pic of one that would be awesome... i really have no clue what i'm looking for here.
Thanks![]()
8" Mill SpeedFit File
Single-cut for gradual material removal
General purpose file for shaping material or restoring sharp objects.
Tooth pattern, coarseness and length combine to determine filing results.
Uses the SpeedFit handle system for comfort and safety.
I'd opt for the file.
My concern is how the woodruff came completely out in the first place. Actually Jim, I could see it getting jammed between the gears and the lower case. There isn't much room between them and the under power the aluminum case might get broken. I just don't quite understand how the key came completely out of the keyways. There isn't enough room on the back side and the gear should have held it in on the outboard side.Missmichelleb,
Did you find out for sure what caused the problem...it is unlikely that the woodruff key could do that!
Jim
