You're welcome Dan. Its been over two years since I made this thread. I spoke to my buddy that owned the bike I used in the pictures and to this day he still feels the affects of the accident....and Thank you big time Easy Rider for starting this thread
Sorry to hear about your accident, I'm glad you didn't have any serious head trama even though you hit your head hard enough to lose a tooth. For reasons like yours, I alway wear a helmet even though I'm testing in the front yard.hi people the front fender is dangerous please eliminate. I am fall no helmet only 15mph I lost a tooth,wound in the forehead knee injury,shoulder injury,I was taken by ambulance.
yes brother helmet ever all along and check the screws the front fender the vibration looseSorry to hear about your accident, I'm glad you didn't have any serious head trama even though you hit your head hard enough to lose a tooth. For reasons like yours, I alway wear a helmet even though I'm testing in the front yard.
Thats a cool helmet. That'll get their attention for sure. lol. Good idea.Very true Pat. Also a helmet gives a subtle clue that your going faster then a bicycle. I can tell the difference when on rare occasion, i forget to put one on. Cars pull out on me a lot less when I am wearing a helmet. It's a big goofy one, not a bicycle helmet.
Found some very cheap fenders I might try. They look break away. Amazon.com: Zefal Mountain Classic Bicycle Fender Set, Black: Sports & Outdoors
Wow Pat, glad you cought it! The whole face plant thing is not fun.So today I removed the fenders from my Cranny and guess what? Yep, you guessed it. The fender was cracking around the metal tab. Another week or so and I might have had a problem. I love forums like these. Thanks for all the input guys.
Pat
That is precisely what I did with mine. My fender bracket is gently squeezed between two rubber washers with a locknut at the end. I also have a springer fork. I went a step further and figured the arc the bracket would travel, from the axis of the fork pivot, and gently bent the bracket to align with the path it would travel along the arc. In this way, when the fork flexes up and down, the bracket travels straight up and down with no need to flex. I had to also futz with the addition and subtraction of washers to find the right path to it, but by then I was so in the zone that I didn't know, or care, that I had gotten anal-retentive to the point of constipation. But, what can I say, still no sign whatever of cracking. And I do check that thing as part of my pre-ride checklist.The problem I've found with making the mount stronger is the fender cracks around the mount or around the bolts/rivets used to secure the mount to the fender. The best solution I've found is replacing the tabs with a small eyebolt and 4 rubber bibb washers.
Mount the eyebolt to the fender, eybolt/washer/bibb/fender/bibb/washer/nylock nut then mount the eyebolt to the fork/fender support the same order.
I came up with this when I switched over to a springer front fork and because of the straps being mounted to the axle there is quite a bit of flex needed where the fender is mounted to the forks. Seems to be holding up pretty good so far.
