While I'll agree completely about the desirability of being able to lace yer own rims... learning how to has been on my "to do" list for way too long lol, made worse by the fact my last build has unusual & oversized hubs. For now I'm content entrusting that to the local bike techs, it's not costly and they're skilled and friendly. What with the weight & speed of that ride... I'd rather not "experiment" with that 'un heh - actually the guy that built my wheelset is even somewhat proud of them and the bike they're on which is flattering to say the least as he's usually occupied building far more costly & fancy wheels
I'll muck about with my other build & it's standard rims at some point tho.
...I also see people talking about master links. If you have a chain tool you should never need a master link.
The master link debate is another story however, I sincerely believe that it's not just a matter of personal preference - but also very much build dependent. On my 21 speed motorized mountain bike w/the standard sprocket adapter there's not a master link to be found as between the derailleur and the tensioner it's really a simple matter to deal with rear wheel removal etc.
Yet my 3 speed vintage cruiser w/shiftkit would be just about impossible to deal with without master links, I'd need to disassemble the jackshaft to easily remove the primary and secondary chains. While I
can get a chain breaker on them, it's a freakin' nightmare w/little to no clearance - far
far more trouble than it's worth. Even the tertiary (crank to wheel) I find far simpler to have a master link on, even though I can easily use a chain breaker on it - I find it much easier & more convenient to pop off the master link to facilitate removing the rear wheel. I've already got a flat screwdriver & spare link in the kit... I see no need to carry a breaking tool for that one chain.
I see no valid reason to
not use a master link if it helps with maintenance, while some have bemoaned the "reliability" of master links, I suspect that any failures people have had stemmed from incorrect installation. I've had way too many master links on all sorts of machines in far more trying applications than a bicycle and never a single failure to suspect the master link itself was the culprit. Honestly, if someone were the type to put the clip on backwards and/or use a malformed, damaged master link - they'd be no better off using a chain breaker as there's just as many ways to use a breaker incorrectly lol
*shrug* As with so many things, it's a combination of knowledge, maintenance, application & preference.
