Bikeguy Joe
I mean two strokes can be flooded but it takes and expert, or a serious carb problem.
try joes suggestion next,
choke off, hold the throttle wide open and pedal like **** and get back to us on what happens with that
ok...for one i dislike those carbs...second, yes the star nut on the clutch can be set...just take the set screw off and turn it to the right, to tighten,...it sounds like its set enough to start...everthing we do from this point is to start it...the fine tuning comes later...ok...the white wire is disconnected and taped, right...because if it is grounding the bike it will cause the bike not to start...have you disconnected the kill switch...?get right back to me...i;m in reno on your time, so i'll stay with you untill we ge it started...Dennis
your not trolling by any chance are you?
i dont understand. im just gonna sit back and watch out of total confusion.
good luck buddy
I can donate a two pound hammer...![]()
I know that on Briggs lawn mowers if the key is just a very slite shear it won't run. Might look ok but if it has a slite indent it knocks it off. Like Fossil I haven't had any experiance with the engines you have but worked on small engines them all my life.
My son has one now and will sone find out.
I had a similar problem a week ago on my new engine with about 50miles on it, the problem was partly due to a fuel valve which would never shut off and flood my carb, but the reason it would not start was a wire came lose. Check your wiring I checked this last because everything ran great before I had shut it off, my carb was flooded and had spark. Lastly I removed the electrical tape and noticed blue wire came undone. fixed, and have been running great ever since. Hope this helps.
how old is the plug? it may be showing spark, BUT is said spark hot enough?
