Eliminating the driven sprocket
paul
5,547
44
48
67
Kalamazoo, MI
yes bottom bracket is in inside the round part at the bottom of the bicycle the cranks screw to. they can cost alot for a top of the line one
Ilikeabikea
2,322
69
Ptown, Texas
So Pablo, will your crank fit the bicycle I have in the photo? The other frame I was going to use has the one piece crank. I actually think this frame will be less work than the one I originally was going to use. I just want to make sure whichever one I use will work with the jackshaft.....................
Pablo
Dec 28, 2007
3,696
33
48
Duvall, WA PNW
www.sickbikeparts.com
OK I put the 10 tooth gear on and rode like a maniac - balls to wall on pavement and chuckholed gravel roads - man it's spring - I got bugs on my teeth. I beat it hard, so hard that I scared myself enough to stop and check everything over. Nothing loose. (^)^5
OK if the production sample gears show on Monday and they fit and work - we will start spending our $1000's of dollars to get production rolling. Can you say "VISA and Mastercard"?:eek::D
Ghost0
763
Bellingham, WA
Pablo, weren't you supposed to be at your daughter ball game?
I don't know if Ilikeabikea's frame will hold a engine. Those extra tubes might get in the way.
Just for some clarification on the bottom bracket. You need what I think is called "cup and cone" style. Attached is a photo of the type of spindle that your current bike should have. If you have the newer style I am told that it can be retrofitted back to the old style.
Ilikeabikea
2,322
69
Ptown, Texas
I don't know if Ilikeabikea's frame will hold a engine. Those extra tubes might get in the way.quote]
I'm going to remove those tubes from the seat post up to the neck and weld in a bar so it will be a boys bike when I'm through. I bet I'll have lots of room if I do that. The main reason I asked was because the frame I was originally planning on using was a boy bike but it has the larger pedal bearings. I just want to make sure the freewheel crank will fit the frame....................:D
