Motorbicycling.com Member Map of Motorized Bicycle Enthusiasts
Dave31
Original post edited to update link and instructions:
Another way to access is to click the Members link in the menu bar. There is a sub link called "Member Map".
The link above is a direct link to the Motorbicycling.com Group member map
Looking for members near you? Someone to ride with? Find members near you to help with your motorized bicycle? Here is a great way to find Motorbicycling.com members.
There is a minimum of 5 posts before you are automatically added to the map.
Once you are added, you can move or update your marker if you'd like. You can also opt out if you prefer, by clicking on your own marker, and checking the opt-out box in the top left corner of the box showing your name.
Re: Motorbicycling.com Member Map
Thank You Nougat, I forgot to post how to do it :o
Also it ask to save something? I think its your Edit URL( I did not pay attention lol) That way you can edit and update your info if need be.
Use your username thats on the forum, that way members that want to contact you they know who you are on the forum.
Looking for someone to ride with? Can you offer welding, custom tanks, bikes, engine kits, parts, repair help.... ect. Not a bad ideal to add that to your description.
I'm in there now Look for the Yellow Marker it's near Washington, D.C.
Here's the map I'm the yellow pin or marker:
Here's the LINK: Motorbicycling.com
Peace Crazy Horse.
Thanks for your hard work Fairracing! Im in..
Kevlarr I used a screen shot with a Linux os.
I can already envision that with 75 more markers added..... you connect dot-to-dot, you should see an image of a motorized bicycle .......try it! laff
Hey look, I'm in TJ rotfl
Wow....check out the map in Satellite mode.....those little hot air balloons really come alive with colorlaff
