LOL I thought I measured right ..it doesn't fit in my frame. I can get the engine in but the screws aren't long enough. Its because it is a very tight fit. Anything I can do(besides to get a new bike)? I know they make screw extenders..would that work?
Another question can I put an engine that suppose to go on the fork in the back?
I used a round file to make adjustment to my motor mounts.
They were somewhat like shown in Alf's tutorial as 'incorrect'.
Because I fitted the mounts well to the tube, I have had zero problems with the crummy china mm studs, though I should replace them with better quality anyway.
Good luck
rc
I cheated there on several of my builds by cutting several strips of lead flashing sheet, of varying width to stick in there to shim out the space.
When I clamped it down hard,(stock studs) the lead mashed and conformed to the space. After tightening a couple more times after some use, this has worked well. One bike has almost 2000 miles now with no engine mount problems.
I have built 7 chinagirls. I never any trouble with the stock studs at all. Just made sure they were seated well just before assembeling.
I agree with Alf.
Copper is superior to using Pb.
The lead will just get hammered out by the vibration.
Even Al beverage cans cut for shim stock get hammered and become worthless in many applicatons.
Best
rc
