What NGK Plug Should I use?
Discussion in 'Motorized Bicycle General Discussion' started by Mpgmotobiker, Feb 1, 2013.
  1. Mpgmotobiker
    Mpgmotobiker New Member
    Oct 30, 2012
    6
    I have been using the Z80 stock motors. What size NGK plug should I use for a stock motor? The climate here in Delaware is Hot summers and cold winters right in the middle. I just need alittle hotter plug than the stock plugs that are offered on the sites
  2. GearNut
    GearNut Active Member
    Aug 19, 2009
    5,105
    NGK BR6HS or B6HS. The R = resistor type, not necessary according to some folks, but I always run a resistor type with CDI ignitions and recommend their use with CDI ignitions.
    FYI, the stock heat range would be a "7".
  3. Venice Motor Bikes
    Mar 20, 2008
    6,170
    NGK -B6HS in the summer, & NGK -B5HS in the winter. ;)
  4. dodge dude94
    dodge dude94 New Member
    Jun 8, 2012
    1,017
    Unless you ride like a bat out of he11 in 100 degree summers like me, then get a B7HS.
    :D
  5. darkhawk22
    darkhawk22 New Member
    Aug 17, 2010
    733
    I'm in Georgia and I have good luck with the combo that Norm (Venice Motor Bikes) mentions.
  6. Venice Motor Bikes
    Mar 20, 2008
    6,170
    I do concur with DD94... a NGK #7 is a colder plug & a good choice for 'Wide Open Throttle' riding in extreme desert heat.
    The summers here in So-Cal aren't really that hot. :/
    #6 Venice Motor Bikes, Feb 4, 2013
  7. dodge dude94
    Jun 8, 2012
    1,017
    I will say this about the B7HS: GREAT PLUG in the hot, or if you're running that engine HARD like I do.
    However, it's a bear in the cold; it takes FOREVER to warm up under 70 degrees it seems.
  8. SubieGuy
    SubieGuy New Member
    Sep 3, 2012
    39
    I'm rocking the BPR6HS (#7022) not sure what all the other letters mean, but it works great!
