Upside Down and Turned Around?
Discussion in 'Motorized Bicycle General Discussion' started by Goat Herder, Aug 12, 2010.
  1. Goat Herder
    Goat Herder Gutter Rider
    Apr 28, 2008
    6,251
    #1 Goat Herder, Aug 12, 2010
  2. Goat Herder
    Apr 28, 2008
    6,251
    #2 Goat Herder, Aug 12, 2010
  3. Goat Herder
    Apr 28, 2008
    6,251
    #3 Goat Herder, Aug 12, 2010
  4. Mind_Reader7
    Mind_Reader7 New Member
    May 1, 2010
    393
    If you're doign a full suspension bike, you could use a spring loaded tensioner maybe?
    Otherwise I don't see a reason you can't just turn the engine backwards, besides possible size issues/the chain will be in the way.
  5. Kevlarr
    Kevlarr New Member
    Jul 22, 2009
    1,628
    As long as the carb faces the right way these motors can run in any position imaginable.
    A friend has an OOOOOOld 60" bar chainsaw that actually has a float bowl carb on it. The carb is part of the handle and if you want to turn the saw on it's side you push a button that releases the handle and lets you rotate it so the bowl is still facing down.
  6. curtisfox
    curtisfox Well-Known Member
    Dec 29, 2008
    4,182
    71
    Why don't you mount the engine on the rear? I did with a friction drive motor. I just welded some extra arms off the swing arm for the mount. Can be seen at SB worksmam site. Kind of like Thats DAX rear mount
  7. Goat Herder
    Apr 28, 2008
    6,251
    #7 Goat Herder, Aug 15, 2010
  8. Venice Motor Bikes
    Mar 20, 2008
    6,192
    19
    How about a shift kit?? Post a pic of the bike!
  9. Venice Motor Bikes
    Mar 20, 2008
    6,192
    19
    If you wanna go crazy & cut & weld on it a bit?... You could stretch the frame & use a shift kit!! (^)
