Hello everyone. First post. A friend recently did a conversion and turned me on to the idea. I picked up a Trek Lime Lite (aluminum frame) on FB Marketplace to use as the canvas. Odd bike... has a 3-speed computer-controlled automatic transmission. Front wheel hub is a magneto that powers a computer under the crank. The computer uses sensor to measure load and speed and actuates a gear selector at the rear wheel to select one of three speeds. Evidently, there is a planetary 3-speed transmission inside the rear hub.
Anyway, planning on using a 100cc black-engine kit. I already cleaned it up a bit by removing reflectors and extra stickers (primary branding is under the paint clear coat, so it will stay). I inverted the handle bars and removed the grips. The seat bracket was inverted to get it an inch lower, and I cut 1.5 inches off the seat post receiver to get the seat as low as possible.
Waiting on a crank removal tool so I can get the rest of the plastic chain guard off. It will get a black steel chain guard as well as flared black fenders. Thinking about swapping out the plastic pedals for retro steel rat trap pedals.
Hope to flip this one (to at least break even) so that I can start on my second build (... and third). Already have a couple ideas for rad retro bikes.
