Packed the muffler with one of these stainless steel scrubbies. Fluffed it up and poked it to the top of the can with a long screwdriver. I picked up two 2-packs, but one scrubby was more than enough. I also cut the exhaust tube off the bottom of the cap because there was no room to push it back into the can.
We'll see. It is mostly air in there. Easy enough to change it up if it is too restrictive. Remember, I doubled the number of holes in the tube and added a couple holes to the bottom cap.That's not going to work!!!
The muffler won't be able to breathe through all that!![]()
BTW... The 5 large bolts only hold the chainring to the adapter. There are five 1/4in bolts that go through the spokes (on a circle if seven - skip instance numbers 2 and 6) and through the two-piece retainer.It looks interesting!!
What keeps the hub adapter locked into the hub to drive the wheel, (besides the five large bolts)?
That fix is very simple!Crank hits the exhaust. I think I will cut the exhaust pipe by the flange and rotate it so that the muffler discharges directly under the bike frame.
That’s pretty trick and nice use of technology.Retaining ring print is almost done (9 hours). Two halves which interlock. 20mm thick, but honeycomb interior with only 20% infill. 3mm wall thickness.
This part will not see any torque from the engine. It is strictly to keep the chainring adapter full engaged with the hub. Will be secured by 1/4in bolts with deformed thread lock nuts.
Finished. I took it out for a couple miles. Engine doesn't run smooth -- sounds like a hit and miss motor. Need to figure out if it is a fuel or spark issue. Spark plug is an E3-32. I replaced the boot with an MSD 90 degree non-resistor boot because the spring boot that came with the kit did not fit tightly on the plug. I am thinking fuel is the issue. I honed the mating surface on the cylinder where the carb attaches and made a new Felpro gasket. I am wondering about the janky clamp set up that attaches the carb -- maybe not sealing well?
I'm running 16:1 with Stihl synthetic oil (this ratio was recommended in the instructions for the first tank - after that, it specifies 20:1). It does run a little better once it warms up. I was hoping that after running it a bit I could open it up and get it to even out, but nope.The bike's looking good!!& good job on that sprocket adapter!
As far as the poor performance... How are you mixing the gas & oil? (I would jump right in with 32:1)... Too much oil will cause poor performance
Another thing to consider; these engines need to get real hot before they start running good.
Also... they run better at higher RPMs; (so, trying to cruise it at low RPMs can cause that missing feeling that you're describing).
