springer forks+breaks...what can be done?
Discussion in 'Motorized Cruiser Bicycles' started by zazbeam, Jun 18, 2010.
  1. zazbeam
    zazbeam New Member
    Apr 15, 2010
    8
    Anyone know how to add breaks to springer forks? Would discs work?
  2. CoastalCruiser
    CoastalCruiser New Member
    Apr 28, 2010
    338
    Side pull caliper or drum is no problem. Discs won't work because of the movement of the fork. If you want disc brakes on the front you need a solid or telescoping fork. V-brakes are possible but you have to figure out how to mount lugs, though I seem to recall a post on here referring to some pre-lugged custom jobs. I hope that helps.
  3. chainmaker
    chainmaker New Member
    Jan 19, 2010
    2,597
    Actually check with VeniceMotorbikes, hes a member here, He makes, and sells disc brake adapters for springer forks, and other forks as well.
    Cheers
    Chainmaker
  4. Venice Motor Bikes
    Mar 20, 2008
    6,174
    Yep, I make disc brake adapters for all forks!
    (Thanks Chainmaker for the plug) ;)
  5. KiM
    KiM New Member
    May 5, 2010
    301
    100% incorrect LoL.. I have disk brakes on my springer you must fix the calliper on the rocker not the fork tube, calliper can go either below or above the disk too have done both in the past ...
    KiM
  6. Terry Blow
    Terry Blow Dealer & Custom Builder
    Oct 29, 2009
    1,117
    Hey Venice Carry's a very nice front end and he has the adapter I recommend his forks I think he has two versions a standard one and a reinforced version you just have to decide witch one you can afford
  7. CoastalCruiser
    Apr 28, 2010
    338
    Well, Excuuuuuuse Me! :)
  8. TYFOON
    TYFOON New Member
    Jun 15, 2010
    10
    Sturmey-Archer makes a sweek front hub dum brake. [email protected]
    I bought one but am not going to use it. Switched bike plans and the new bike has v-brakes.
    I bought a springer fork also....that is not going to get used from pistonbikes.com.
    Foon:-||
