misteright1_99
eDJ, I agree those are the 2 issues to be addressed and they work hand in hand. It is practically impossible to get the sprocket "perfect" to center, and therefore you always have a tight and loose condition as the wheel turns, especially in my case as I am runnig a 50t sprocket, a smaller sprocket say 1mm out of round is not going to be as bad as a larger sprocket. The spring loaded tensioner keeps the chain tight on the drive sprocket during the loose condition, as well as cut chain slap. I tried to go without a tensioner at all but when tight I was afraid it was putting to much strain on the sprocket bearing, rear sprocket, engine mounts, etc. The other is the stock #415 chain is junk and I feel to narrow for the sprockets especially when new, they "stick" to the sprockets and alot of times have to have a dremel or grinder to remove some of the metal edges to release the chain.
P.S. This post was posted by the Admin. to the "Classic Instructions" section for others to use...
