Right now I am running the Simplex clone tires, which is to say I am running Quick Bricks. I think I'll need a whole Saturday to squeeze on the Simplex tires, but I'll get them on there. I have to for safety.
Pat,
Nice vids on Flikr man...all i can say is POST MORE!!!
I did a little R & D with some different setups and you would be surprised with what I have found...
I forgot you were running without a governor. Those numbers I gave were for the stock 3600 rpm. check out these links
speed calculator
Rawge's Mini Chopper Information Site - Jackshafts
ratio calculator
Rawge's Mini Chopper Information Site - Gear Ratio
As far as the oil goes I always used 3/4 qt just like cobra.
Re-jetting the carb (drilling the main jet larger) will fix the flat spot. The two holes in the starter pulley works good because if you crash it wont work like a chain saw into your leg. Did you catch anything while hunting?
Lurker,
What happened to the ratio calculators? I just tried to access them with no luck. I have a 44t being cut and want to verify my rpm verses speed.
What kind of speed were you able to achieve with your current set up?
