race bike, pit bike, or death trap?
I agree... it's looking like a real contender!
short-coupled, low CG... I guess yah just gotta work on the speed and torque now?
Gosh I really hate the Pnut tanks!
I hate my own more every time I ride the bike!
Yah,yah... they work, they're cheap... but the rib around 'em does me no good, and, everybody has one! :-)
Good luck with the new mab!
rc
thanks, silverbear...
i hate those peanut tanks, too. its just on there for now.
i've got a piece of aluminum pipe that fits in the space. gotta figure out how to tweak it into the tapered part, and that's gonna be it.
should hold at least 1/3 gallon, which is plenty enough for a 15 lap race.
Wow Baird, looks like a switchback killer you put together. Oh and brakes? Sometimes you need to tap em for the apex :p
If you understeer crash any more I'ma get one of the mods to change your s/n tag to "crash bairdcoot" :D
Lookin great, buddy!
The peanut tanks look WAY better if you put some chrome plastic car door edge molding on it like this.
I love it baird!
low siding with the pirellies is hard to do....But I have a video of me sliding 30 feet on wet asphault with them anyway LOL. (& me without my gear on...ouch ouch ouch....at least chicks dig scars)
I am running the #s for another aperance in sunny california with a pile of my junk to ride around.....
If I can make it, the china girl 50cc will be my #1 priority bike & the zappy will be the distraction.
as allways, good work.
yeah, i'm thinking of dropping knees with a bike this low. if it does go down, i hope it it's on the right side. otherwise, i'll be picking my "side draft" mikuni off the track...
here's some lousy nighttime pics. offset manifold for a 16mm mikuni, and the start of the tank. tank should hold a whopping 30oz. should be enough to cross the finish line. didn't have enough time to finish it, but it'll be done soon.
the engine is a reversed-barrel GT5A, and with the carb and some tuning, it maxes out at 35 before the horrendously unbalanced motor shakes your hands off the grips and loosens your bowels.
i'm gonna switch the case with an old GT4 and see if that helps. it detonates like crazy at high RPMs, probably due to the ridiculously small combustion chamber, but i need a slant head to fit it in the frame.
or, i might be able to re-mount it with a straight shorty plug. i ain't giving up yet. i'll make it work somehow.
my goal is 40mph. with the way it handles corners, that's plenty enough speed in the straights.
Very nice baird. Looks like a screamer!
if you don't mind me asking, wht happened to the orrigonal forks seat & seatpost?
P.s, puch mkes 22 inch wheels. Mags and spoked. I've got like 3 spair sets of tires for my 72 maxi sport
original forks, headset, and stem were rusted into one piece, along with the cranks and the bottom bracket. those got bandsawed off.
the original seatpost is on it, and i have the rusted out seatpan somewheres.
i just looked at the before picture i posted. actually, the bars, grips, and the cranks were added after i cut the old ones off. it's an old picture. the bars are floating around here somewhere's...
yeah, those forks are cool. the brace for the truss rods was welded on. the steertube's only like 3.5", though. i cut the brace off, and when i get better at welding i'll probably use it on something.
this bike is turning out to be a giant headache.
the GT5A motor is crap. everything about it is crap. i've tried 2 of them so far, in various configurations.
first, stock, with an NT carb.
vibrations at 25-30, enough so you can't hold onto the bike. head gasket blew after 1 day, even after changing the head studs and hardware to some high quality **** with flange nuts instead of the acorns.
added another base gasket to decrease the compression. still vibrated, detonated, and just plain sucked.
rebuilt and reversed the motor, built the "side draft" manifold for the mikuni, trimmed the piston skirt, cleaned the ports, matched the exhaust and cut out the catalyst.
speeds about 35, then massive vibration again. head gasket blew in 20 minutes. sanded the head (warped), added another base gasket and another head gasket, no change, head gasket blew after an hour, vibrations broke my manifold.
next, used a GT4 case with a balanced crank, and the same GT5A jug and head, reversed style with a shorty intake and an NT carb.
vibrations lessened, but detonated like crazy, won't idle, and the jug and head have such lousy tolerances that the piston seems like it's just rocking around in there. blew another head gasket.
swapped the motor back to normal configuration, still using the GT4 case. added a custom made, awesome expansion chamber.
NT carb is in the way of the clutch cable. bike makes weird noises like the piston's not connected to the rod, or the bearings are falling out, or like someone's shaking a jar full of change.
still managed speeds about 35, vibration's still there, i'm starting to think it's the frame.
after a ride to the liquor store (10 blocks total) there's oil leaking from the head gasket.
took head off and threw it against the brick wall a few times because i couldn't find my BFHammer.
that didn't fix it either.
made a conclusion that the GT5A motor is the biggest piece of **** that ever came over from china. as long as i live, i will never put another one on a bike, work on anyone's bike that has one, and never comment on one again.
in other words, i wash my hands of it, and disavow any knowledge of it's existence. but not before putting a curse on anyone and everyone involved in it's development, manufacture, and assembly of it. i hope an earthquake destroys your factory.
moving on, i now have a GT5 in place. although it's from the same accursed factory, i had one in stock configuration on the Monark Raffle bike, and it reached 40mph with a 34t sprocket, with no mods other than an NT carb and match porting the intake and exhaust.
the GT5 has been reversed, piston skirt trimmed, ports cleaned, and i'm building a manifold for the Mikuni, using my newly acquired (and still learning) welding skills. enough of this alumiweld soldering crap. i'm also building an expansion chamber for it.
the first problem i've encountered is that the GT5 is almost 1/4" thinner than the GT4 and the other crap motor who's name i refuse to utter.
big deal, right? only a 1/4"...
now, my chain rubs on my super cool moped tire.
tomorrow, i will buy a KMC 415 chain to replace my Diamond 41. if it continues to rub, i will hone my welding skills and weld a slightly offset, adjustable plate for mounting the motor straight to the frame. it will need to be slotted, because if this motor doesn't provide me with the level of satisfaction i'm accustomed to (which is a very low level, considering the quality of engine's i'm working with) i will need to throw it away and put something else on. preferably, something that hasn't come out of the skyhawk factory (the one that will soon collapse in a localized earthquake. if the factory is built with the same craftmanship as their engines, a very small earthquake will do the trick. maybe even a good door-slam or a car backfire...)
as far as the tank goes, i haven't got to that point yet. i've only spent 3 weeks trying to get a motor to work, so i'm a little behind.
with any luck, this bike will be ready for the Bairdco Racing Association's first race of the year 2013
i've decided to name this bike the "Albatross."
It really sounds like you are going 4-stroke now, or need to.......unless you wanna go electric? It's still only a matter of time ;)
dnut
i can't fit a 4 stroke in this bike. i can barely fit the china doll in there.
i think i wanna build a morini next, or something more exotic. like a turbocharged aprilia...:)
Think Polini ;) Liquid cooled at that......
dnut
Seems like you had the same probs as my gt5a. Mine vibrated so hard it cracked the frame.. And constant hg leaks...
