Could someone tell me what size the nuts are on a cylinder head for a 2stroke 49 and 66cc? What type of socket will I need? Cause I can't seem to find one that will fit between the fins. Thanks.
nuts 13mm = M8Could someone tell me what size the nuts are on a cylinder head for a 2stroke 49 and 66cc? What type of socket will I need? Cause I can't seem to find one that will fit between the fins. Thanks.
most are sizes right, but good point. one of my kits came with two washers and a lock nut washer under all my head bolts.. and im thinking its because the acorn nuts bottomed out.DON'T FORGET if acorn nuts bottom out you run a chance stripping the studs out of the motor case!
