Discussion in 'Introduce Yourself' started by drob, May 14, 2009.
  1. drob
    drob New Member
    May 1, 2009
    7
    Hello Everyone!
    I live in Kansas City and am in the process of building my first bike. The first bike was a road bike and my attempt was a disaster! The sprocket did not clear the frame so of course I had to find another bike but I had already purchased a 4 stroke kit on ebay with a three piece crank/sprocket/pedal assembly and the new bike, Schwinn Jaguar, is a 1 piece crank assembly! Do any of you know how I can take care of this problem? I've looked at most Bike Engine conversion sites and checked their parts section and no one has replacement 1 piece crank/ sprocket/assemblies.
    Hope someone can help, Thanks!
    Duane
  2. Dave31
    Dave31 Moderator
    Staff Member
    Mar 1, 2008
    11,207
    13
    Welcome, glad you joined us.
  3. drob
    drob New Member
    May 1, 2009
    7
    Thanks, I've been reading a lot of the posts here and have to say they have been a lot of help but the only way you really learn at something like this is to get your hands dirty!
  4. Cabinfever1977
    Cabinfever1977 New Member
    Mar 23, 2009
    2,290
    buy a 3 to 1 piece crank converter $18,it will make your 3-piece fit the 1piece hole.
    i used short crank peddals from a exercise bike and paid $3
    #4 Cabinfever1977, May 14, 2009
  5. hiker472
    hiker472 New Member
    Nov 6, 2008
    651
    Speaking of converting the cranks, does the one-piece slide out of the hole or do you have to straighten it?
    BTW, drob, welcome to the fun!
    .wee.
  6. Cabinfever1977
    Mar 23, 2009
    2,290
    it just slides out as you turn it a little.
    you couldnt straighten it if you wanted too.
    #6 Cabinfever1977, May 15, 2009
  7. drob
    drob New Member
    May 1, 2009
    7
    Thanks Cabinfever, although someone else asked about straightening the crank in order to remove it. I have done quite a bit of checking today and I need to a lot more than just replace the crank with an axle. It seems that one piece cranks in the cruiser bikes have different size housing. So, the long and short of it is that I have to install a conversion in the housing to reduce the size and then install the new axle, etc. The conversion kit is around 35$, which is o.k. because this is my first build and I am learning a bunch of lessons!
    Thanks again
    Duane
  8. Cabinfever1977
    Mar 23, 2009
    2,290
  9. drob
    drob New Member
    May 1, 2009
    7
    Thanks Cabinfever, it looks like it might fit although from what I found out yesterday, I'll need to call them before I order because there are several different considerations such as axle length, thread size, size of square ends for pedals, etc. Unless the bike dealer was blowing smoke up my butt of course! Anyway,thanks for the link to the Bike Parts site! I'll use it for sure!
    drob
