Glacknoid,
Break-in:
It won't make any difference either way. Just don't over-rev it, and make sure to load the engine without lugging it. Standard break-in procedures apply.
atombikes,
The plastic camshaft will undoubtedly last for many, many, hours. I would be willing to bet that this method of making a camshaft is common among many of the small 4-cycle engine manufacturers. The cost saving is huge!!!
Looking at both methods,
8620 Steel:
Drop forge to create a blank...with accompanying tool cost.
Hob the gear...again tooling costs.
Copper coat and case harden, (heat treat), to .045-.060" depth.
Finish grind the lobes...More tooling costs.
Plastic: I don't know the compound, but I would suspect it is something similar to glass filled teflon. It may be as simple as graphite acetyl.
Manufacture a precision pin...case harden.
Place pin in injection mold...fill mold and release.
This method requires an injection mold that would be equivalent in cost to the drop forging die for the steel cam.
All subsequent operations pertaining to the manufacture of the steel cam have been eliminated...which results in a huge cost savings.
The engine is very well made, and nicely machined...the price is incredible!
Obviously, if this engine takes-off for use as an alternative MB power-plant...a lot of owners will be looking at ways to increase the RPM...which goes back to my original post.
Unlike a flat head, (valve-in-block), engine...the overhead valve engine is encumbered with the mass of pushrods and rocker arms. Of course the overhead valve engine is capable of making more horsepower...but there is always a trade-off!
There is a point where the inertia from these moving parts will overcome the tension of the valve springs, (valve float). For those who don't know...when the valves float, they fail to seal...and the engine will just fade away power-wise until the RPM drops to a point where the valve springs can seal the valves.
Naturally stiffer valve springs will resolve the valve float issue and allow the engine to continue to rev...but then we have...the plastic cam.
I'm going to rework this engine to turn 8,000 RPM, using the plastic cam...I'll let ya'll know what happens.
Jim
