New and no spark.
Well done! It was totally loose inside.!! Thank you so much. I'm going for a ride to see what else may need to be questioned.
Okay, I'm hoping this is the last question but also so grateful you are here to answer my questions! So, now that I'm riding around with a properly tight choke, when I pop the clutch and ride, if I try to stop the engine by engaging the clutch again, she keeps idling... I mean does not stop not even a little bit of I push the choke down she kills. What to do? Please and thank you! Liza
Did you wire the 'kill switch' correctly?
There are two wires, color doesn't matter. Those wires should be spliced into the blue and black wire connections between the engine and the CDI.
When you want the engine to shut down you depress the kill button which is on the throttle. Some buttons are red, some are yellow.
