My motor is making a clanking sound
Discussion in 'Motorized Bicycle General Discussion' started by athletichunta, Aug 18, 2010.
  1. athletichunta
    athletichunta New Member
    Jul 22, 2010
    114
    34 miles in and motor is clanking when i pull the rip cord?.
    its a 49cc 4 sroke huaseng motor or w/e the brand is called, i forget.
    I was revving it with the tire off the ground around the time it started happening. I was just cleaning it tho, and was trying to dry the tire off a bit.
    Does anyone know what is wrong with it?, or if this is normal?. Thanks.
  2. athletichunta
    Jul 22, 2010
    114
    Its now also idling extremely high and make a ton of noise.
  3. tvance7
    tvance7 New Member
    Jul 26, 2010
    Yes. I know. You have a connecting rod about to throw. The rod bolts have backed out.
    You need to take apart the engine and replace the rod. Also any other parts that are shot.
  4. athletichunta
    Jul 22, 2010
    114
    Alright well i managed to fix the throttling problem, it was just a zip tie i put on before around the throttle cable tubing that was pulling the throttle a little.
    Now the clanking sound problem still persist, it rides but it keeps sleeping and can reach a high speed anymore.
    Then afterwords its not staying on at all without loosing power and turning off as soon as its started.
    Now is there anything I can tighten to fix this problem or is the engine shot?.
  5. Dave31
    Dave31 Moderator
    Staff Member
    Mar 1, 2008
    11,207
    14
    athletichunta, If you are still under warranty I would contact the vendor you purchased your motor from.
  6. skjjoe
    skjjoe Member
    Mar 9, 2009
    393
    sounds like a bad engine to me
  7. scotto-
    Jun 3, 2010
    6,530
    6
    I know this sounds a little unusual, but I'm gonna put my money on the post above....#3.
  8. Kevlarr
    Kevlarr New Member
    Jul 22, 2009
    1,628
    This is a completely normal condition after putting 2.5 times too much oil in an engine, running it that way until it dies then draining all the oil out and once again running it until it seizes up.
  9. 2door
    2door Moderator
    Staff Member
    16,301
    26
    I'm trying very, very hard to hold my tongue here. Another perfectly good engine destroyed in less than 50 miles. Too bad. :(
    Do not lift the rear wheel and run the engine at full speed. Do not turn the engine on its side and pour in oil until it runs out. I hate to see a piece of machinery mistreated almost as much as I hate to see a dog mistreated.
  10. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    pics,we want pics
  11. athletichunta
    Jul 22, 2010
    114
    Sure, but Pics of what?.
    Well at first I put 20 oz of oil into the engine and ran it for about 3 minutes, then I later dumped it out when it stopped starting, I ran it less than 25 seconds total without any oil in it just to see if that fixed the none starting problem, it did, but the broken clutch switch vibrated to the right and stopped it from starting again, I didn't realize until the day after. From here I put the recommended 4oz of oil in it and rode it around for 2 days totaling about 50 miles, that's When the motor died. I drained the oil out of it and it was all black and smelt terrible. Also around 42 miles of riding something on the motor started blowing warm air out of the left side onto my leg.
    O and its confusing.. I did fix the loss of power thing, it was the kill switches wiring, nothing to do with the motor, Sorry I forgot to mention that.
    This is not to mention the slight clanking sound when I pulled the pullstart. I didn't think much of it as it was still running perfectly and it didn't make any sound while It was on.
    What I think broke it was the 4oz of oil in it, because the smell of the motor was putrid right after it broke. I know it wasn't the smell of gas, so it must have been the oil.. What els could it have been?.
    So just a Heads up to anyone that has this motor, I recommend to put 8.4oz of oil in it, never 4 or els it will be fried within 50 miles. I'm not pointing fingers, im just saying..
    #11 athletichunta, Aug 19, 2010
  12. Kevlarr
    Kevlarr New Member
    Jul 22, 2009
    1,628
  13. mr.WFO
    mr.WFO New Member
    Aug 14, 2010
    17
    go for warranty,
    if not, pull it apart. if it's not the clutch or rod you might have gremlins.
    i've found an extra bolt inside a honda lawnmower engine...
  14. ocscully
    ocscully New Member
    Jan 6, 2008
    373
    The recommended amount of oil for these motors is 250ml (8 oz.) in the crankcase, not 4oz. Where did you come up with the idea that 4oz. was the proper amount? As for the clanking noise you talk about I think that the members that have said that you probably have a loose connecting rod are pointing you in the right direction. There have been several members recently who have had the oil slinger break off the bottom of the rod cap due to the bolts loosening and the slinger then hits the bottom of the crank case.
    ocscully
    #14 ocscully, Aug 19, 2010
  15. athletichunta
    Jul 22, 2010
    114
    I made a double post of this thread on accident, and now the other post got deleted. But here is what happened.
    http://motorbicycling.com/f3/i-think-kit-i-bought-came-22099.html
    Originally Posted by athletichunta View Post
    My motor seized About 5 minutes ago I think. The pull start is completely locked.
    The person that is (Physic) Y did you delete your post about the 4 ounces of oil?, did you mean 8?, because I think you might have just cost me a motor.
    Ummmm.....read your first post!
    4oz. of oil was recommended by more than one person and that IS approx. what the recommended capacity of this motor is! Any more questions???
    EDIT: Let me clarify, in your first post (of multiple posts) in this thread you said you put 20ozs. of oil in your engine. For 1; I seriously doubt 20 ozs. would even fit in this engine. 2; you drained it and ran with no oil in it. 3; advice has been givin to you, but you fail to adhear to any of it. 4; It sounds like you bought a bad motor to begin with and you continue too make it worse. 5; no one is responsible for ruining your already broken motor but you.
  16. Bikeguy Joe
    Jan 8, 2008
    11,529
    I think this thread ended with oscullys' post...
  17. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    this thread started suspeciously strange
  18. Bikeguy Joe
    Jan 8, 2008
    11,529
    I once ran an 84 ford tempo without oil for 25 seconds and guess what happened to it? Yep, a clanking sound....and I wasn't even holding the wheel off the ground.
  19. r00t4rd3d
    r00t4rd3d New Member
    Aug 2, 2010
    310
    I ran a Honda ATV for about 5 miles with zero engine oil and guess what happened ?
    nothing.
    I ordered a new drain plug , filled it back up and ran it till I sold it.
  20. Kevlarr
    Kevlarr New Member
    Jul 22, 2009
    1,628
    Anyone remember the old infomercials for I think Slick 50 where they would drain the oil out of a car and drive it around? I always wondered what kept the lifters from collapsing and rattling like crazy. That and the running engine that didn't have a valve cover or oil pan and they dumped "dirt" into the valve train, only thing is the dirt was vermiculite. lol
