Put in the aluminum clutch I got from ebay for $9 .......... but the clutch did start to scream when it go hot I guess because it was slipping.
hi !
would be more than clever resonable to make a woodruffkey groove into the Clutch center plate (most of the 3-shoe clutches these days are without the Groove even that Cranks have the Groove. some cranks do not have the Groove..)
as the 3-shoe Clutch center/base plates are relatively skinny, it would be good to modify the STD woodruffkey by lowering it so that Groove into the Base plate would not have to be so deep.
end of Clutch Slipping at Crank and BURNING making the crank shaft Diam smaller !
i have 6 Cag engines, all 40mm diam Bores. all them are assemblyed and made in different factoryes from different Submanufacturer parts brands (casting marks logos etc), which is of course super intresting as i can see various differences on them.
for example i have 3~4 different Crank assy models, with different conrod's etc. and also some are with and some without Clutch w-d-key grooves.
the Clutch w-d-key is exactly same as Flywheel w-d-key.
on my Std 3-shoe Clutches (that i dont use) the Clutch arms are Aluminium alloy. Difficult to read tell about the manufacturer logo as its Vague.. The 3-shoe Clutch model of mine as New weights 289Grams if i remember correctly (i have notes at home..)
my model:
http://www.miniatureimports.co.uk/images/DSC06769.jpg
MINI MOTO MINIMOTO DIRT BIKE RACE BIKE QUAD CLUTCH 3 SHOES (FREE CLUTCH SPRINGS) | eBay
Those Steel metal center/base plates ive seen at least 3 different models regarding Pivot Bolt fittment and Blate Material, other good service able and other Mushroomed Punched locked even that it has M6 thread in it (Not good model at all)
That linked clutch above is with the Perfect Base/center Plate (material and M6 Pivot bolt fittment ideology..)
as a test i ordered "heavy duty" springs (titled so) from ebay seller "Hk-motos", and they by eye are exactly same as those springs on Above linked Clutch.
These:
Mini Moto Performance Clutch Spring Set 3 Springs Parts | eBay
And what comes to your unknown metal object ( i havent looked the photos yet) and conrod bottom end Needle bearing type/model, its highly possible that Needlebearing can collapse burn seize partially especially if engine has been running Lean no matter short or longer period.
these Cag Needle Bearings are not High tech or best Quality. For example some Topend Needle bearings will popout a Needle if ya drop the Bearing into table from 20~50cm distance BECAUSE the Free floating "Locking mechanism" for Needles is very Loose and tiny about 0,1mm or so Cage material Crushed at each end of Needle....
This is not a Problem as the Sideways movement is very little @ Needlebearing/piston/conrod fittment and Needle Bearing wont ever have a "Peak out" more than approx 2mm from each side....
But anyway, always check carefully Topend NeedleBearing(s).
race Conrod's for 125cc 2t's etc can have "Less friction totally Floating Loose Needles" at Bottomend Needle Bearing, which are assemblyed with Grease when assembling Crank assy/fitting Conrod assy. in a Controvercy to Old fashion regular NeedleBearing Constructions...where Needles are permanent "fixed fittment" to Needle cage..
Bye
m
