I'm guessing this is the same guy we had problems with before 2door.
Apparently he is still a bit butthurt.
Don't even worry about it.
I don't get upset over inarticulate ranting from wannabes.
Map that's the way I was thinking of using a twin plug head and the toggle switch. I'm thinking you would get a high voltage arc across a switch on the plug wires. Resistors and diodes don't like voltage going the wrong way. At high rpm you would probably take out the cdi not being used at the time.
Using a double pole, double throw toggle will take care of the low voltage ignition wires. It's the high voltage lead that is the bug-a-boo. I'm not going to spring for a cylinder head, no matter how many spark plugs it will holdBut I am going to figure out a way to get one plug to fire from two sources.
That will be the only way I see of a close to real comparison. Stopping to switch plug wires, to me, seems to negate the whole concept. The switching action will need to be almost zero resistance for the test to be definitive. I'm thinking, I'm thinking...
Lol........!Double blind testing with all the riders blind folded.
I'm already half blind and deaf. Does that count?Double blind testing with all the riders blind folded.
