KC's 68cc 4-stroke 4-speed soft tail
Discussion in 'Motorized Bicycle General Discussion' started by KCvale, Jun 16, 2014.
  1. KCvale
    KCvale Active Member
    Feb 28, 2010
    3,886
    19
    That is entirely true.
    There were no trees or even cactus to speak of in the Gully Tracks, just a usually dry river bed and a lot of desert eroded from monsoon storms to make it very un-even, hence Gully's, and an absolute blast to dirt bike on.
    Hurt myself many I time as well but didn't ever seek compensation from the land owner for my foolish behavior.
    I got my drivers license and a jeep in my Sophomore year (mid '70's) I think and we would go 'desert romping' in the wash and Gully Tracks as well, that went over way worse.
    You really can't do much damage to anything on a dirt bike, but you sure can in a 4x4.
    That flat chunk of desert playground as mentioned is covered up now but the scares I left on of the mountains with the 4x4 remain.
    I have mixed feelings about that...
    Ya, the mountains have some unattractive scars, but I was the one that managed to climb it when there was nothing there, the proof remains 30+ years later, and few things compared to sitting on top a mountain you drove up that nobody else ever had.
  2. KCvale
    Feb 28, 2010
    3,886
    19
    Just got the DHL tracking# for the frame (jumps up and down) ;-}
  3. redneck82
    redneck82 Member
    May 25, 2014
    126
    dude, your bike's bad ass!!! im looking at building something along those lines with an rx50 upgrade kit... boosts it up to 125 also a 4 speed... im doing on a limited budget though so im scrapping it together from a few different bikes...
  4. KCvale
    Feb 28, 2010
    3,886
    19
    Actually it seems they are made in Kachsung Taiwan, at least that's where it shipped from.
    [​IMG]
    Cool redneck.
    What does that 'upgrade kit' have that turns a 50cc's power into a 125cc's power, a turbocharger or something?
    That would be something wouldn't it, a turbocharger for these little 4-strokes?
    Hehehe.
    This was supposed to be a powerful but cheap 4-stroke build.
    I snagged the engine for under $300 delivered and was just going to mount it on a ~$350 bicycle frame until a 'friend' on my business forum pointed out that that 'for just a couple thousand more I could have...' a pre-jackshafted full suspension dual disc brake bicycle with specific mount points for the engine I just bought it was a no brainier.
    $2500 for a bicycle in today's world is nothing for the serious rider, heck this electric shifter I am still dinking with (breaks drive chain) is on a $3,500 Specialized frame.
    [​IMG]
    With $1,200 in electronics in that Specialized I could darn near build 2 of these 86cc 4-speed 4-strokes on Motoped frames for the same price.
    #24 KCvale, Jul 5, 2014
  5. redneck82
    redneck82 Member
    May 25, 2014
    126
  6. KCvale
    Feb 28, 2010
    3,886
    19
    Near as I can tell that has no gears, just cent clutch and no carb.
    Can't see how you mount it either.
    Good price for a 4-stroke regardless until you start adding up all the extra stuff you will need to buy.
    I always have to smile at an ad for just an engine can rate it's top speed (65KMH) when they have no idea what wheel size the engine will be mounted to.
  7. redneck82
    redneck82 Member
    May 25, 2014
    126
    http://m.ebay.com/itm/160298036886?nav=WATCHING_ACTIVE
    there we go... this ones a 4spd mani trani ... tells you in the description whats needed...
    i got the prices confused before... this one is $245... other was like $256... still short money either way... but yeah this is another thatll make you laugh... "max speed 65k/h"
  8. maniac57
    Oct 8, 2011
    4,486
    Hey KC, Your area should have decent used Honda donor bikes available used since you live in the desert...
    Why risk unknown clone quality and parts interchange when you can find original Honda motor and freshen it up (depending on donor miles/use/quality) for nearly the same money?
    The original XR motor will RIP in that frame! Eat the lunch of any clone, much less with a 125cc kit...
    I work with a local scooterstore owner and trust me, the clone quality is NOWHERE CLOSE to Honda. Not all the parts are exact interchange either.
    In my opinion, spending the coin for a motoped and using a clone, is like building a prostock drag car and powering it with a junkyard motor.
    If you're gonna drop $2k on a bicycle, I'd make sure it was a real Honda.
    Just MY opinion.
  9. KCvale
    Feb 28, 2010
    3,886
    19
    If you followed this thread I bought the engine first as it was a heck of deal with no idea what I was going to mount it on. If it turns out to be crap, lesson learned.
    I'll know soon enough as the bike frame is LA now so I should have it in a couple of days.
    [​IMG]
    Guess I better take a look at the engine now ya think?
  10. Citi-sporter
    Citi-sporter Member
    Jun 16, 2014
    120
    My experience with the Honda clones has been positive, I own two bikes with a 100 and 125 CC engines. One has over 10,000 miles, still has good compression and runs well.
    The Lifans are remarkably stout and durable, ( caveat..) as long as you do regular maintenance. Check the valves clearance cold before firing up the first time. I'd also stick to a 1000 mile oil change routine and drain the shipping oil the engine comes with and replace with a good quality Dino #30 or 10-40 like Delo 400 LE for the first break-in, ( cast-iron cylinders need to be broke in gentle..) and changed at 300 and 600 miles for the first two changes as there will be a bit of break-in wear metal-flakes that gets suspended in the first two oil uses.
    This is normal for the clones.
    If you are getting an oil cooler type engine, get the best cooler you can buy, it will help in Arizona especially.
  11. KCvale
    Feb 28, 2010
    3,886
    19
    The 'bike' is here.
    It didn't come as pictured, it came in a box the size of residential AC unit.
    Inside the big box is a bunch of smaller boxes and the tires.
    [​IMG]
    [​IMG]
    I think 'some assembly required' is one heck of an understatement, I expected a 'bike in a box' with the handlebars and front wheel off and such like all the other bikes I buy in a box, in this case I have to build the darn frame before I can even get started.
    No biggie, just time consuming for a pet project so it gets the back burner for now.
    I do feel for the DHL driver though...
    It's monsoon season and he got here at 'prime time' for the heat.
    Better he sweat than me however so I showed him where to put the box in the shop with just a little help from me once it was inside.
    Anyway it's here, let the adventure begin ;-}
  12. Davezilla
    Davezilla New Member
    Mar 15, 2014
    2,708
    Nice... That's at least one step closer than most of us are who want to build one of those bikes..
    I just had to shell out big bucks on setting up my new auto shop (and still got a lot more bucks that need shelling out) but once the money starts coming in instead of going out I'll be ordering up a kit for myself, but for me for now it's still just wishful thinking... just hopefully not too much longer...
  13. scotto-
    Jun 3, 2010
    6,527
    Nope, the owner of the company told me they gave the contract to China to build them as the quality and the price was far better than what the US or Germany and a few others could offer them.
    Made In China.
  14. maniac57
    Oct 8, 2011
    4,486
    I would not call them "crap", just not up to Honda level of build quality.
    I KNOW you like your stuff equipped with the best so I wondered if you had thought of it.
    Not a problem since you can always re-power it down the road if needed.
    I'm a real fan of Japanese dirt bike motors, including the laydown Honda's!
    The ATC90 style motor is nearly bulletproof.
  15. redneck82
    redneck82 Member
    May 25, 2014
    126
    in terms of the one im building its an experiment... im def glad for the brake in advice! and im up in new hampshire so the whole extreem hot isnt nearly as much of an issue... i am still up in the air however on going with the automatic or the mani 4speed...
  16. KCvale
    Feb 28, 2010
    3,886
    19
    Whatever you go with make sure it doesn't have a clutch lever, the bike has independent hydraulic disc brakes.
    And I can paint it because I'm not building it on this ugly charcoal gray main frame.
    It is far from a rolling frame however.
    [​IMG]
    1280x view http://KCsBikes.com/pics/MotoPedFrame1-1280.jpg
    4000x view (warning, huge detail!) http://KCsBikes.com/pics/MotoPedFrame1-4Kx3K.jpg
    Man it sure has a beefy swingarm/jackshaft, real motorcycle quality, and look at those welds!
    Some instructions would have been nice.
    The only instructions I got are how to deal with the hydraulic disc brakes, it's kind of like a jigsaw puzzle with no picture on the box top at the moment but I'm a clever guy and may have it to a 'rolling frame' by the weekend.
  17. scotto-
    Jun 3, 2010
    6,527
    It's pretty straight forward for anyone with the ability to build bikes from the ground up.....just assemble it. If you need instructions, you may be in trouble laff
    EDIT: I'm still trying to figure out what this thread is doing in the "Motorized Bicycle General Discussion" forum? Seems to me it might be a little bit more appropriate in the 4-stroke forum here?
    #37 scotto-, Jul 9, 2014
  18. redneck82
    redneck82 Member
    May 25, 2014
    126
    bah... still puttin motors on bicycles... just bad ass ones lol
  19. Goat Herder
    Goat Herder Gutter Rider
    Apr 28, 2008
    6,250
    Is that motor free spinning at all when you get to your shifter? That thought just occurred to me? Dunno?
    If you got enough torque on that motor? I found out early in my MJShaft NV get up I made,, only a BMX HD chain could stand up to the fight and that was close to no good by 1,200 to mebbe 2000 miles tops. That chain will be laying on the ground or if lucky some how tangled up. That problem stopped when I gave up on Dérailleur shifters.
    The BMX chain was getting changed out every 800 miles for me at optimal performance expectations.
    That was single speed chain to a N.V. hub gearing set to run pretty high against the hub's for more anti slip inside the hubs gearing. on a mebbe 5.8 H.P. morin motor at the time. That could be why I did not blow that hub then?
    I don't think you are running more than 1,200 watts are you? If it is that torque'y of a motor??? How hard is this bike launching?
    #39 Goat Herder, Jul 9, 2014
  20. KCvale
    Feb 28, 2010
    3,886
    19
    Just under 1KW nominal on a 35 pound bike.
    I put a wide-spaced 7-speed cartridge on and running Z33 HD 5-speed chain now, it seems to be holding up fine no matter how hard we beat on it but I'm with you, internal gears and HD 410 chain.
    The motor has a freewheel sprocket so no drag from pedaling or motor power, and of course the pedals freewheel.
    (smiles at Scotto)
    I have built plenty of bicycles from the frame up, this ain't no bicycle frame, these videos were helpful however in getting the right parts in the right place.
    https://motopeds.com/how-to-assemble
    I went with 5 coats of AZ sun baked on gloss black PlastiKote high temp engine paint, and a couple of coats of lacquer on the frame.
    It didn't need high temp paint, I just like the stuff.
    [​IMG]
    Everything else in the shop is done so it's time to start getting this thing together.
