Thanks, I think you're right chainmaker as it's a simple yet effective set-up when your options are limited.Very cool Scotto !! I bet we are going to see more of this.
It's really not much different than letting off the throttle on these bigger bore 4-strokes and letting the engine's compression do the braking.Very cool idea...But I'm wondering about transferring the braking forces from the hub to the drive chain.
FR
The rotor was made from a 28t cog that was part of a older chrome plated Shimano Hyper-Glide cassette.......works like a champ.Did you make that rotor out of a old chain ring ? good thinkin man .
Nice mod , awsome idea .
The only prob with that set-up in my application is my rear sprocket is 4.1mm thick.....I don't know of any bicycle disc-brake caliper that would accept that thickness. A caliper from a motorcycle may work, but the expense and weight would be considerably more I'm sure. Would make for a clean set-up though, I've seen them before.Another route to go ( and they make these for motorcycles also ) is ,if your rear sprocket is big enough ( for the clearance ) , to use the rear wheels sprocket itself as the brake rotor ,
Just mount the caliper in the open area in front of the sprocket .
The thing i like about the sprocket-rotor setup is .. it looks cool .. its a clean setup .. less parts ( no need to add a rotor because the sprocket is the rotor )
Looks great man and I wouldnt have guessed that the rotor was from a cassette.The rotor was made from a 28t cog that was part of a older chrome plated Shimano Hyper-Glide cassette.......works like a champ.
I've seen similar set-ups on scooters and go-karts in the past....AGK has been running them on bikes for a while now. It's great for when you have very limited rear wheel space and you want more than a coaster brake for rear stopping power and controllable modulation.
The locking collar is the center part of the Congress V-pulley (pictured) that was in my never ending parts pile in my garage. They're cheap to buy new however, but I like using stuff I have lying aroundLooks great man and I wouldnt have guessed that the rotor was from a cassette.
Where did you get the locking collar that the rotor mounts onto?
Thx
