I did both CVT for awhile and then switched to internal hub. Not only was the nexus the same price as a cvt+a spare belt, I could not find a chinese CVT that was not junk and needed new bearings. I pushed that thing home many times and spent more money on belts than I can remember. Always had to have a spare. Once I got the CVT set up correctly, I began breaking clutch drums. Yea, a combination of 52cc's of heavy duty torque and cheap chinese CVTs. Maybe your normal china girl with peddle assist doenst break these things so easy, but my no-peddle recumbant scooter motor can pump it out below 6000 rpm's.
So.... I set up the internal hub as a jack-shaft. I use the shimano nexus 3 speed that is sold for torker tricycles. It has a sprocket for the right side in place of a spoke flange and makes it 'ready made' for my application. The nexus absolutely ROCKS!.
52 cc. 2-stroke scooter engine with a 5-to-1 reduction transmission and a 12 tooth output sprocket. Stock configuration, tops out some where between 6800 and 7600 rpm's under load.
The frame is a monster cheap ass steal stand-up scooter with a bicycle front end. The thing weighs a ton compared to a regular bike frame.
Set up as a jack-shaft, I can develop 42 MPH in third, fully loaded with tools, and with lights blazing off the front dyno-hub.
1st pulls up to 20.
2nd starts pulling around 15 and gets me to 30+.
3rd begins to hit the torque at 27 mph and gets me to 42.
The system cruises very quietly and raises little suspicion from the cops while rolling 25mph in 3rd due to the lower rpms.
My next hub will be the 5 speed. I believe it will get me to 60 mph.
The hub never even gets warm. As a jack shaft is is very efficient and allows you to gauge the amount of torque it needs to handle by adjusting sprocket and wheel sizes.
If you have doubts about a hub's ability to handle the power, increase the RPM's that it spins and translates. Assuming you do a jackshaft, the higher the rpms of the hub, the less over-all torque per linear foot that the hub must process.
Here is my gear calculator.
http://www.thebitstream.com/scoot/
So simple to set up for me,
WaaHoo! lets blaze!
1st pulls up to 20.
WaaHoo! lets blaze!
