If you bought your engine from Chris Hill you should have received a good instruction book with it. In the installation guide Chris explains how to tighten the bolts and warns against overtightening them. Loctite will be your friend for life and will assure those nuts stay put until you need to remove them. DO NOT weld the nuts in place. The heat will effect the already questionable steel of the studs and you might find them seized in the aluminum engine due to the heat.
Following Chris Hills advice, tighten the nuts just enough to flatten the lock washers and then just a VERY SMALL tug past that point. Do not retighten those parts every few days. Inspect them if you want and if a lock washer appears to be opening, then and only then apply a wrench to the nuts. Retorquing these studs and nuts is one of the biggest mistakes I hear people on this forum make. Tighten them once, check after the engine has reached operating temperatue a couple of times then leave them alone. Yes, the Chinese metal isn't the best but even replacing it with grade 8 material won't help if you strip the threads out of the aluminum engine case. Good luck with your bike. Let us know how you're doing and if you ever feel like doing to the CH-80 what you did to the ebay motor, give me a heads up first. I'll take it off your hands and save you the emotional stress.
