The tri car part of the trike did indeed get painted and the bike frame was done today. I feel that the two of them turned out well for being painted with a rattle can and black at that. Black is infamous for showing up every imperfection for those that haven't used it. I always heard that is why so many hot rods were painted bright colours. Only the builders that were really sure of their work used black.Probably a rumor but every bodyman I worked with took extra care when a car was painted black.
Me? I don't give a $%*# and the fenders and rims were painted black anyway. Black was one of the colours available in that year also.
I don't have any photos yet of the exquisite paint work but I plan to put the bike together in a couple of days or as soon as the bike frame hardens up some more. Nothing like looking down and seeing your finger prints in the "dry" paint.
Made up some spring holders to center the springs on the king pin. The hole in the spring is 1-1/8" and the king pin is 3/4" so the spring slopped around quite a bit and tended to jam on the spindle. The "top hats" centered on the king pin being 3/4" inside and the outside of the tubing is 1" so it left a little play in the spring spacing so they won't jam and bind.
I used a lighter, smaller diameter washer on the top of the spring and cut notches on both sides so it slid into the spindle holder at the top. A heavier, larger diameter washer was used on the bottom since the spindle and the whole bike will ride on it. I'll use either an Oilite or Teflon washer top and bottom of the spindle to make steering easier.
Steve.
Steve.
