Im stuck!
Discussion in 'Motorized Bicycle General Discussion' started by HBfisherman, Jan 27, 2010.
  1. HBfisherman
    HBfisherman New Member
    Jan 5, 2010
    74
    Ok so I finally got my motor yesterday, and I attempted to start the installation. It wasn't easy, I ended up only taking off the rear wheel and disassembling the axle because it has a peice of metal that attached the rear wheel to the frame that had to go inorder to put the sproket on. I don't know if this is a peice that has to be on the bike in order to work properly but I had no choice but to take it off. But the only problem is I cant get it off, I ended up unscrewing the bolts and finally got the greasy axle off but wasnt able to get the other bolt off so I can take that metal peice off. I ended working till midnight last night and only got as far as taking the wheel off, Im weak! Please help me what do I have to do to get this thing off?
    [​IMG]
    #1 HBfisherman, Jan 27, 2010
  2. Venice Motor Bikes
    Mar 20, 2008
    6,192
    19
    It's not as easy as it seems is it??
    After you've done a hundred of 'em, it gets easier! ;)
    Theres a thread here somewhere with a diagram of how to put it all back together...
    I'll see if I can find it.
  3. HBfisherman
    Jan 5, 2010
    74
    Def. not easy, I got the axle back together but cant get that metal thing off, do I need it? Thanks for looking Venice!
  4. 2door
    2door Moderator
    Staff Member
    16,308
    30
    That is the coaster brake anti-rotation bar, HB. It needs to go back on but it will need to be bent a little to clear the sprocket. Read the post that Venice is getting for you about coaster brakes, dust caps and what you'll need to do to get things right. Good luck.
  5. Finfan
    Finfan New Member
    Aug 29, 2008
    871
  6. HBfisherman
    Jan 5, 2010
    74
    Ok if I bend it and put the sproket on how will I be able to bolt it to the frame?
  7. 2door
    2door Moderator
    Staff Member
    16,308
    30
    The arm will need a slight 'Z' bend put in it to clear the sprocket/bolt heads. It should go right back where it was with just a little offset which the clamp that held it should allow. If the arm was attached with a screw to a welded bracket on the frame, very rare, then a little adjusting there might be necessary.
  8. HBfisherman
    Jan 5, 2010
    74
    After installing the axle back in, im not sure I installed it correctly. Is the stock sproket supposed to move at all or is it to be fixed?
  9. Bikeguy Joe
    Jan 8, 2008
    11,529
    The pedal sprocket will operate as usual. If that sprocket is locked, you have something wrong in the rear hub assembly.
  10. HBfisherman
    Jan 5, 2010
    74
    Its locked!
  11. bairdco
    Aug 18, 2009
    6,375
    36
    i could come by and fix it. i charge 50 bucks an hour...;)
  12. 2door
    2door Moderator
    Staff Member
    16,308
    30
    You have a coaster brake hub. The sprocket should not spin free if you try to rotate it forward, or in other words, the direction the pedal chain tries to turn it. It will have a little freeplay backward until the coaster brake engages then it should not turn.
    Watch that Bairdco guy...he's building a new bike and needs all the cash he can pull together.
  13. Randog707
    Randog707 New Member
    Oct 18, 2009
    177
  14. Randog707
    Oct 18, 2009
    177
    Also if wheel is locked up it could be the two brake pads in the coaster assembly,take it apart agin and make sure the 2 pads are in the right position.
  15. HBfisherman
    Jan 5, 2010
    74
    I love the internet, thanks guys when I get home I pretty much know what I have to do. Im pretty sure that the pads were put in wrong.
  16. HBfisherman
    Jan 5, 2010
    74
    I'v been working for the past two days and I only got the sproket mounted on the rear wheel. I took apart the coaster brake and im not sure if I put it back properly. What is the function of the rear wheel, what is supposed to move and what is not. It seems as everything is frozen nothing is moving and im pretty sure I put the coaster back the right way, am I not supposed to tighten it to tight? Also, I didnt have the tools to cut down the dust cover so I bent it to fit in the the sproket hole, is this bad?
  17. marts1
    marts1 New Member
    Sep 18, 2009
    392
    The axle should be tightened just enough to get rid of any play. Donno if I'm anywhere in the ballpark here but tyg.
  18. HBfisherman
    Jan 5, 2010
    74
    #18 HBfisherman, Jan 29, 2010
  19. Cabinfever1977
    Cabinfever1977 New Member
    Mar 23, 2009
    2,290
    I would say maybe the dust cap is now bent and jamming up the wheel.
    Or the inside nut on the peddal side freewheel sprocket might be too tight.
    #19 Cabinfever1977, Jan 29, 2010
  20. HBfisherman
    Jan 5, 2010
    74
    I did tighten that one pretty good, is it supposed to be loose?
