Scootmeister
Scotto, I read that you can get an aftermarket starter kit for the Predator. The kit would have to include a charging coil to keep the battery up unless it already has one.
It lists the compression ratio at 7.4 for all three which kills the theory about the Honda having higher torque due to a higher compression ratio.
This morning I was on AGK's site and I noticed that they now offer a reground Honda GHX50 cam. Will it properly fit in a HuaSheng 142F, also taking into consideration that it has a decompression device built into it? I have no need for the decompression device, but the slow boat from HuaSheng land for AGK to get more HuaSheng cams to regrind is taking forever.
What do you guys use to seal the split crankcase when you swap out the cam? I guess Permatex would work, I can't quite figure out what the grey putty is that comes on these engines. Whatever it is the stuff works, mine has never leaked.
