Scotto, I read that you can get an aftermarket starter kit for the Predator. The kit would have to include a charging coil to keep the battery up unless it already has one.
Yes, you can get them aftermarket but if you want to go high performance, you have to get the billet flywhweel and have it machined to fit the starter ring. That gets expensive and is not an easy bolt-on task. You also need the extra coil to charge the battery and it bolts on undrneath the flywheel.Scotto, I read that you can get an aftermarket starter kit for the Predator. The kit would have to include a charging coil to keep the battery up unless it already has one.
The GXH50's compression ratio is 8.0:1. That kills your theory killing the "theory" that the Honda has more power due to compressionIt lists the compression ratio at 7.4 for all three which kills the theory about the Honda having higher torque due to a higher compression ratio.
That cam should work fine in the HS and if there is a dc device built in, that's easy to disable.This morning I was on AGK's site and I noticed that they now offer a reground Honda GHX50 cam. Will it properly fit in a HuaSheng 142F, also taking into consideration that it has a decompression device built into it? I have no need for the decompression device, but the slow boat from HuaSheng land for AGK to get more HuaSheng cams to regrind is taking forever.
On the Honda engines, the gray sealant if Hondabond 4. They use it in several applications where they don't use paper type gaskets.What do you guys use to seal the split crankcase when you swap out the cam? I guess Permatex would work, I can't quite figure out what the grey putty is that comes on these engines. Whatever it is the stuff works, mine has never leaked.
