Heat shields and exhaust questions
Discussion in '4 Stroke Bicycle Engines & Kits' started by cdavid67, Apr 23, 2012.
  1. cdavid67
    cdavid67 New Member
    Apr 4, 2012
    34
    Hello all,
    I spent some time researching these topics before I decided to start this thread. As you may know, I am still gathering parts for my build before I start assembly.
    My 1st question is: Can you remove the heat shields and goofy plastic covers from the HS 49cc engine without causing problems?
    2nd: My engine came with a lawnmower looking exhaust and no pipe in the Grubee kit. Is this normal? I ordered an exhaust pipe from AGK so I don't want the stock pipe. Just curious more than anything. I guess I just need to unbolt the stock muffler looking box and throw it out?
    Thank you.
    cdavid
  2. scotto-
    Jun 3, 2010
    6,524
    Welcome to the forum (^) Yes you can remove shields and shrouds but it isn't recommended. As long as you're moving while the engine is running, over heating shouldn't be much of a problem.
    No pipe in the Grubee kit? There should have been one but not to worry if you're gonna use an AGK exhaust for your build. Yes, just unbolt the stock muff and the AGK will bolt right on (use the stock exhaust gasket).
    Have fun with your build and let us see some pics!
    dnut
  3. moonerdizzle
    moonerdizzle New Member
    Jun 28, 2009
    874
    My kit didnt come with a exhaust pipe ether, just the ugly can. and i removed all my shrouding, and made a coffee can shroud for the flywheel following silverbears tutorial.
  4. flmotorbikes
    flmotorbikes New Member
    Mar 23, 2012
    174
    They usually do come with the pipe so the can is weird, Maybe their getting even cheaper
  5. azbill
    azbill Active Member
    May 18, 2008
    3,367
    I have seen 2 engines that were bought seperately (different vendors, engine only) come with the 'can' exhaust
    they are very restrictive :(
  6. old motorbike
    old motorbike New Member
    Sep 21, 2008
    352
