.....Upon opening the kit, I found no instructions on how to put it together, well after trial and error, it was not a big deal. Everything went together rather smooth.]
If you go back to Gasbike's page. Click on the Ghost racer link, scroll down to the description of the kit. There is a downloadable PDF file that is the installation manual. I dicovered it by accident
Here's the link.
http://gasbike.net/images_templ/keyed-manual-7g.pdf
Yep, used it yesterday so I have another 7g on the way to try a bearing fix on.FYI, Gasbike has a coupon for $20 off the 7g kit. The coupon code is GHOST20.
I used the 3rd party billet and NT carb.
The second notch down seems to be ideal on the NT needle and the breather was no issue, a bit longer hose and plastic tube and it fits right in a air cleaner hole.
No intentional disrespect VMB, it's a nice intake, I just couldn't remember where or even when I got the thing as I tend to buy things I don't need at the time but would like to try sometime.NICE KC!!
Thanks for the mention about my carb & manifold that you're using.
You bought it three weeks ago... (& it probably arrived at your door only two weeks ago)!
So don't try to lie & play it off like it's been sitting in the back of your garage (collecting dust) for years!
Your disrespect is very obvious, & I feel like a dummy for sending you those referrals over the years![]()
Wow Norm, I'm sorry bud, what more can I say than my failure to mention you as the maker was not some sort of intentional diss?You bought it three weeks ago... (& it probably arrived at your door only two weeks ago)!
Note I also used a extra 4G base again as the 7G kit base is a joke.
Yes.By base I assume you mean engine mount.
Despite the kit flaws it came rather well I think.
That build is out the door already.Could you do a closeup or two of how you have this set up and how you did it? If I decide to go with the RT carb...rather than the NT carb...would there be any way to do this as you have done with the NT carb?
Almost forgot...do the stock carb bolts work to put the new manifold on or will I need new ones?
If new ones...can you let me know the sizes/lengths?
I don't know what VNB's intake may have came with, but I used a gasket and Allan bolts I had around to attach it as the long stock bolts won't work.
For the breather I just bought some longer hose and shoved some piece of round hard plastic tube I had around that fit both ends in the filter, may have even been drilled, don't know, Cole did that part.
Hehe, ya, it's winter for you already.Am going to order the manifold...so I have that covered.
With my luck...the first blizzard of the season will hit when I get the parts in and installed.![]()
