Saddletramp1200
Custom MB Buiilder
I will have to tell My Point Beach to start cracking. I have ridden it daily with a DAX 66 for over four years.
Getting ready to throw down some dollars for a Felt. Common sense says that the steel frame is by far the more durable, however I see alot of you guys using aluminum frames. Why is that? Being a super noobie, I want to buy the most durable frame, engine, etc. Seeing as how I'm aiming for max power (considering a 9HP Morini), low maintenance. So, aluminum or steel?
brazed and silver soldered frames need no post or preheat when used on chromolly
so TIG is not the only answer
I would LOVE to see you tig a lugged frame
Pro Tips:
aluminum = light, brittle
steel = soft, heavy
I built this frame out of steel and all the joints were tig welded with Silicon Bronze filler rod. I will add a couple gussets in certain areas and that's it. I have built a few frames and did some good research with the supplier of the filler rod. That’s why I chose it.
http://motorbicycling.com/showthread.php?t=39900
Another venture I am on is an aluminum frame with some steel areas mixed in; the main part of the frame will be aluminum. We shall see how that turns out.
The bottom line is I favor steel, but like working with aluminum due to the ease of fabrication.
Now ask me what frame I would chose for a Motorbike build if I had to chose one to purchase...I think Scotto has the answer...
I guess what I haven't the capacity to understand yet is: What advantage or for what purpose would someone mx n match metals?
That - while somewhat true, is an exaggerated simplification yank...
Just about any metal that's used in bicycle frames should be heat treated/annealed/tempered/case hardened/through hardened after welding to optimize the alloy's properties... as an example 4130 chrome moly is particularly susceptible to embrittlement as a result of welding, requiring both pre-heating and post-weld stress relief and the heat control only TIG is capable of, yet I don't see anyone saying "chrome moly is bad" - and I suspect none of the box store bikes are treated in any way whatsoever save paint, regardless of the material used.
Generally speaking these post weld treatments are side stepped in both mass-production and shop fabrication by simply using additional gussets, more weld filler and thicker material than could be utilized in the ideal treated state, the hydroformed/extruded 6000 series aluminum commonly used for the lower cost bicycles no exception.
The applications these heat treatment welding protocols are adhered to stringently are primarily in the most extreme cases of minimalistic construction, aerospace engineering for example - or for our application, the very best of the "high-end" bicycles, where every ounce of excess material is considered a liability... but those bicycles should not be modified in any case, not just for welding/treatment concerns but also the focus on minimalist weight conservation engineering.
It all boils down to common sense, if you start with an overbuilt platform (such as a mountain bike) of even average acceptable quality (wall thickness & factory welds) and are familiar with basic construction & engineering concepts - welding/modifying any material is simply a matter of considering "acceptable risk" and compensating as necessary...
...yet if you are not familiar with such basic construction & engineering concepts and/or utilize only the lowest quality/most inexpensive platforms to modify in any way (including simply motorizing something not designed for such) - no material is "safe" and it all entails some amount of risk. If you have even some fabrication & modification experience, using aluminum has no greater risk then steel - yet if you have little to no experience in fabrication and welding, the material alone won't make any difference.
Again, it's not so much about the material used - it's the design that material is used in that needs be considered, the care & quality in which it's constructed... and that's so variable with our hobby, there's no clear cut rules, no easy answers - for every post warning against aluminum there's an equal or greater number of reported steel frame failures. Every motorized bicycle on this forum has been modified well beyond it's initial operating parameters, every one a risk to some degree - simply focusing on the material used without considering it's design is the fundamental mistake here, most focusing on price and/or aesthetics alone.
