Drilling Freewheel Hub For Larger Bolts
Discussion in 'Motorized Bicycle General Discussion' started by 5-7HEAVEN, Feb 19, 2012.
  1. 5-7HEAVEN
    5-7HEAVEN Well-Known Member
    Aug 2, 2008
    2,364
    37
    I have SBP's HD White Industries freewheel one on my 72t engine sprocket/shift kit. I removed the crank arm with attached freewheel for SBP's suggested maintenance. It's been a few hundred miles on the road. The wheel's five holes are small, so accept small bolts. My bolts are bending slightly. I want to drill these to accept Grade 8 1/4 x 28 bolts. I tried a reamer, files, even cobalt drill bits, but they don't even scratch let alone cut thru the tough steel. The machine shop will drill the holes oversize for $80.....or more.
    I'd rather DIY.
    I have a HD Milwaukee 1/2" drill (not cordless), but it's not doing the job.
    What do I need? :-||
  2. H.R. huffinstuff
    H.R. huffinstuff New Member
    Jan 27, 2012
    49
    tough ass drill bits, oil, patience and a strong wrist
  3. bandito
    bandito New Member
    May 22, 2009
    783
    Get a HF drill bit sharpener and have patience. Oil and slight pressure is all thats needed as long as the bit is cutting material. Fast isn't the best either if you can regulate the drill speed.
  4. Ibedayank
    Ibedayank New Member
    Oct 29, 2011
    1,171
    case hardened steel just won't drill. you can grind it but will take a long time
  5. 5-7HEAVEN
    Aug 2, 2008
    2,364
    37
    I dunno, man. After an hour of drilling, not even a scratch.:-||
    The small hole is EXACTLY the same size as when I started.
  6. 5-7HEAVEN
    Aug 2, 2008
    2,364
    37
    So what would you suggest?
  7. scotto-
    Jun 3, 2010
    6,530
    6
    It can be done........and as others have suggested. The main thing is low speed. May take a handfull of drill bits or sharpening bits several times and a good cutting oil. Go slow and be patient.......or pay $80.
    dnut
  8. The_Aleman
    The_Aleman New Member
    Jul 31, 2008
    2,658
    Access to a drill press and a wide size range of new drill bits will do it. Baby steps :D
  9. 5-7HEAVEN
    Aug 2, 2008
    2,364
    37
    Thanks guys. I'll buy more bits and keep trying for now.
  10. dtj6ppc
    dtj6ppc New Member
    Feb 23, 2011
    61
    Anneal soften the holes by heating, the hole areas only, to a cherry red and let air cool to room temp., drill using slow rpms and fast feed rate to create long cutting metal slivers that will prevent work hardening.
    Not sure about this, but your problem maybe that you are trying to drill thru quality chromed surface which can be difficult until the chrome layer is penetrated and you get to the softer underlying steel base material.........Don
